<!– Class –> This is the derived class of the class DbfMatchingPlugIn for matching Census Block Group areas.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin</a>
*System.Object ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin *ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin
CensusBlockGroupDbfMatchingPlugin | This is the constructor of this class. | ||
CensusBlockGroupDbfMatchingPlugin | String | This is the constructor of this class. |
AddRecord | IEnumerable<Object> | DbfMatchingPlugin | This method adds one record to the DBF file. |
Close | MatchingPlugin | This method closes the MatchingPlugin. This method is the concrete wrapper for CloseCore. | |
![]() CreateDbf | String, IEnumerable<DbfMatchingPluginColumn> | DbfMatchingPlugin | This method creates a DBF file according to the specified file name and column names. |
Dispose | DbfMatchingPlugin | Releases all resources used by the DbfMatchingPlugin. | |
GetRecord | Int32 | DbfMatchingPlugin | This method gets a record by record index from the DBF file. |
GetRecords | Int32, Int32 | DbfMatchingPlugin | This method gets records by using the specified range. |
Match | String | MatchingPlugin | This method matches the source text and returns a collection of GeocoderMatch. This method is the concrete wrapper for MatchCore. It firstly formalizes the input sourceText, gets the formalized results and matches them using MatchCore one by one, then returns all of the results within a collection. |
Open | MatchingPlugin | This method opens the MatchingPlugin for use. This method is the concrete wrapper for OpenCore. | |
BinarySearch | Int32, Int32, String, String | DbfMatchingPlugin | This method does a binary search on the DBF file and returns the record it hits. |
CloseCore | MatchingPlugin(overriden) | ||
Finalize | Object(overriden) | ||
Formalize | String | MatchingPlugin | This method formalizes the source text. This method is the concrete wrapper of FormalizeCore. |
FormalizeCore | String | MatchingPlugin(overriden) | This method formalizes source text to get possible census blocks. |
GetKeyColumnName | DbfMatchingPlugin | This method gets the key column name from the DBF file. | |
MatchCore | String | MatchingPlugin(overriden) | This method matches the source text and returns a result with a collection of GeocoderMatch. |
MemberwiseClone | Object | ||
OpenCore | MatchingPlugin(overriden) | ||
SearchLowerBound | Int32, Int32, String, String | DbfMatchingPlugin | This method gets the record number of the lower boundary of the matched results. |
SearchUpperBound | Int32, Int32, String, String | DbfMatchingPlugin | This method gets the record number of the upper boundary of the matched results. |
PathFileName | String | DbfMatchingPlugin | Gets and sets the path and file name of the DBF file to be used for Geocoding. |
RankingMultiplier | Int32 | MatchingPlugin | This property is the ranking multipier for GeocoderMatch. |
ReadWriteMode | DbfMatchingPluginReadWriteMode | DbfMatchingPlugin | The read/write mode for the DBF file. |
RecordCount | Int32 | DbfMatchingPlugin | This record count of the DBF file. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CensusBlockGroupDbfMatchingPlugin.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CensusBlockGroupDbfMatchingPlugin.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CensusBlockGroupDbfMatchingPlugin.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CensusBlockGroupDbfMatchingPlugin.28String.29</a>
| pathFileName | String<!– System.String –> | The path and file name of the DBF file to be used for Census Block Group Geocoding. |
| values | IEnumerable<Object><!– System.Collections.Generic.IEnumerable{System.Object} –> | This parameter represents a record in the DBF file. |
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Close.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Close.28.29</a>
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin –> Go Back
<!– static –> This method creates a DBF file according to the specified file name and column names.
| Void<!– System.Void –> | The newly-created DbfMatchingPlugIn object. |
| pathFileName | String<!– System.String –> | This parameter is the path and file name of the DBF file. |
| columnNames | IEnumerable<DbfMatchingPluginColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn} –> | This parameter is the collection of DbfColumnDefinition objects. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Dispose.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Dispose.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetRecord.28Int32.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetRecord.28Int32.29</a>
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> | The record value. |
| recordNumber | Int32<!– System.Int32 –> | This parameter is the record number. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetRecords.28Int32.2C_Int32.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetRecords.28Int32.2C_Int32.29</a>
| Collection<Dictionary<String,String»<!– System.Collections.ObjectModel.Collection{System.Collections.Generic.Dictionary{System.String,System.String}} –> | The collection of record values. |
| firstRecordNumber | Int32<!– System.Int32 –> | This parameter is the first record number to get. |
| count | Int32<!– System.Int32 –> | This parameter is the record count to return. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Match.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Match.28String.29</a>
| Collection<GeocoderMatch><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch} –> | A collection of GeocoderMatch. |
| sourceText | String<!– System.String –> | The source text to match. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Open.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Open.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#BinarySearch.28Int32.2C_Int32.2C_String.2C_String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#BinarySearch.28Int32.2C_Int32.2C_String.2C_String.29</a>
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> | The record hits in the search. |
| firstRecordNumber | Int32<!– System.Int32 –> | The first record number for the search. |
| lastRecordNumber | Int32<!– System.Int32 –> | The last record number for the search. |
| columnName | String<!– System.String –> | The name of the column on which the binaray search is based. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CloseCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CloseCore.28.29</a>
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Formalize.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Formalize.28String.29</a>
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The collection of formalized strings. |
| sourceText | String<!– System.String –> | The source text to formalize. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#FormalizeCore.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#FormalizeCore.28String.29</a>
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The collection containing possible census blocks. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetKeyColumnName.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetKeyColumnName.28.29</a>
| String<!– System.String –> | The key column name. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#MatchCore.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#MatchCore.28String.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#OpenCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#OpenCore.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#SearchLowerBound.28Int32.2C_Int32.2C_String.2C_String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#SearchLowerBound.28Int32.2C_Int32.2C_String.2C_String.29</a>
| Int32<!– System.Int32 –> | The record number of the lower boundary of the matched results. |
| sourceText | String<!– System.String –> | The source text to search for. |
| columnName | String<!– System.String –> | The name of the column on which the search is based. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#SearchUpperBound.28Int32.2C_Int32.2C_String.2C_String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#SearchUpperBound.28Int32.2C_Int32.2C_String.2C_String.29</a>
| Int32<!– System.Int32 –> | The record number of the upper boundary of the matched results. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#PathFileName” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#PathFileName</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#RankingMultiplier” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#RankingMultiplier</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#ReadWriteMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#ReadWriteMode</a>
| DbfMatchingPluginReadWriteMode<!– ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginReadWriteMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#RecordCount” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#RecordCount</a>
