thinkgeo.mapsuite.mapsuitegeocoder.dbfmatchingplugincolumn
ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn
This structure represents the DBF column definition.
    • System.ValueType
      • ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn
DbfMatchingPluginColumn(String,DbfMatchingPluginColumnType,Int32)
  • This is the constructor of this structure.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn#DbfMatchingPluginColumn.28String.2C_DbfMatchingPluginColumnType.2C_Int32.29
  • columnName
    • Description:This parameter is the column name.
  • columnLength
    • Description:This parameter is the column length.
  • Determines whether the specified Object is equal to the current Object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn#Equals.28Object.29
  • Description:True if the specified Object is equal to the current Object; otherwise, false.
    • Description:The Object to compare with the current Object.
  • Returns a formatted String that represents the current object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn#ToString.28.29
  • Description:A String that represents the current object.
  • Serves as a hash function for DbfMatchingPluginColumn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn#GetHashCode.28.29
  • Description:A hash code for the current Object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn#MemberwiseClone.28.29
ColumnName
This property is the column name.
ColumnLength
This property is the column length.
ColumnType
This property is the column type.
thinkgeo.mapsuite.mapsuitegeocoder.dbfmatchingplugincolumn.txt · Last modified: 2017/03/16 21:59 (external edit)
