<!– Class –> Provides data for the VertexRemoved. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.iOSEdition.VertexRemovedEditInteractiveOverlayEventArgs
![]() | This is the default constructor of this parameter. | ||
![]() | Feature, Vertex | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Feature | This property gets or sets the Feature to be used to remove vertex. | |
![]() | Vertex | This property gets or sets the vertex removed. |
Name | Type | Description |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
<!– ThinkGeo.MapSuite.iOSEdition.VertexRemovedEditInteractiveOverlayEventArgs –> Go Back
Return Type |
Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> |
