thinkgeo.mapsuite.iosedition.vertexmovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.VertexMovedEditInteractiveOverlayEventArgs
Provides data for the VertexMoved. event.
      • ThinkGeo.MapSuite.iOSEdition.VertexMovedEditInteractiveOverlayEventArgs
VertexMovedEditInteractiveOverlayEventArgs()
VertexMovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • movedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex moved.
AffectedVertexFeature
This property gets or sets the Feature to be used to remove vertex.
MovedVertex
This property gets or sets the vertex moved.
thinkgeo.mapsuite.iosedition.vertexmovededitinteractiveoverlayeventargs.1442824518.txt.gz · Last modified: 2015/09/21 08:35 by admin
