<!– Class –> Provides data for the VertexAdded. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.iOSEdition.VertexAddedTrackInteractiveOverlayEventArgs
VertexAddedTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexAddedTrackInteractiveOverlayEventArgs | Vertex, Feature | This is the commonly used constructor. |
AddedVertex | Vertex | This property gets or sets the vertex added. | |
AffectedFeature | Feature | This property gets or sets the Feature with vertex added. |
| Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> |
<!– ThinkGeo.MapSuite.iOSEdition.VertexAddedTrackInteractiveOverlayEventArgs –> Go Back
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
