<!– Class –> Provides data for the MouseMoved. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.iOSEdition.TouchMovedTrackInteractiveOverlayEventArgs
TouchMovedTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
TouchMovedTrackInteractiveOverlayEventArgs | Vertex, Feature | This is the commonly used constructor. |
AffectedFeature | Feature | This property gets or sets the Feature to be affected. | |
MovedVertex | Vertex | This property gets or sets the vertex to be moved. |
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
<!– ThinkGeo.MapSuite.iOSEdition.TouchMovedTrackInteractiveOverlayEventArgs –> Go Back
| Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> |
