<!– Class –> Provides data for the FeatureDragging. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.iOSEdition.FeatureDraggingEditInteractiveOverlayEventArgs
FeatureDraggingEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
FeatureDraggingEditInteractiveOverlayEventArgs | Feature, Boolean, PointShape, PointShape | This is the commonly used constructor. |
Cancel | Boolean | This property gets or sets the action to be canceled or not. | |
DraggingFeature | Feature | This property gets or sets the Feature to be used to dragged. | |
SourceControlPoint | PointShape | This property gets or sets the source control point to drag. | |
TargetControlPoint | PointShape | This property gets or sets the target control point to drag. |
| draggingFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the target feature to be dragged. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
| sourceControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specified the source control point to be dragged. |
| targetControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specified the target control point to be dragged. |
<!– ThinkGeo.MapSuite.iOSEdition.FeatureDraggingEditInteractiveOverlayEventArgs –> Go Back
