<!– Class –>
*System.Object **ThinkGeo.MapSuite.GisEditor.StyleItem
StyleItem | Object |
CanContainStyleItem | StyleItem | ||
CloneDeep | |||
GetPreviewImage | Int32, Int32 | ||
GetRestrictStyleCategories | |||
GetUI | StyleBuilderArguments | ||
ToString | Object | ||
UpdateConcreteObject | |||
UpdateStyleItem | |||
UpdateUI | StyleUserControl |
CanContainStyleItemCore | StyleItem | ||
CloneDeepCore | |||
GetPreviewImageCore | Int32, Int32 | ||
GetRestrictStyleCategoriesCore | |||
GetUICore | StyleBuilderArguments | ||
MemberwiseClone | Object | ||
OnConcreteObjectUpdated | |||
UpdateConcreteObjectCore | |||
UpdateStyleItemCore | |||
UpdateUICore | UserControl |
CanAddInnerStyle | Boolean | ||
CanRename | Boolean | ||
Children | ObservableCollection<StyleItem> | ||
ConcreteObject | Object | ||
Name | String | ||
Parent | StyleItem |
NameCore | String |
ConcreteObjectUpdated | EventArgs |
| concreteObject | Object<!– System.Object –> |
| styleItem | StyleItem<!– ThinkGeo.MapSuite.GisEditor.StyleItem –> |
<!– ThinkGeo.MapSuite.GisEditor.StyleItem –> Go Back
| Byte[]<!– System.Bytethinkgeo.mapsuite.giseditor.styleitem –> |
| screenWidth | Int32<!– System.Int32 –> | |
| screenHeight | Int32<!– System.Int32 –> |
| StyleCategories<!– ThinkGeo.MapSuite.GisEditor.StyleCategories –> |
| StyleUserControl<!– ThinkGeo.MapSuite.GisEditor.StyleUserControl –> |
| styleArguments | StyleBuilderArguments<!– ThinkGeo.MapSuite.GisEditor.StyleBuilderArguments –> |
| styleItemUI | StyleUserControl<!– ThinkGeo.MapSuite.GisEditor.StyleUserControl –> |
| styleItemUI | UserControl<!– System.Windows.Controls.UserControl –> |
| ObservableCollection<StyleItem><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.StyleItem} –> |
| Event Arguments |
| EventArgs<!– System.EventArgs –> |
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
