<!– Class –>
*System.Object System.Windows.Threading.DispatcherObject *System.Windows.DependencyObject System.Windows.Controls.GridViewColumn *ThinkGeo.MapSuite.GisEditor.DataRepositoryGridColumn
DataRepositoryGridColumn | |||
DataRepositoryGridColumn | String, Double | ||
DataRepositoryGridColumn | String, Double, Func<DataRepositoryItem, Object> |
CheckAccess | DispatcherObject | ||
ClearValue | DependencyPropertyKey | DependencyObject | |
ClearValue | DependencyProperty | DependencyObject | |
CoerceValue | DependencyProperty | DependencyObject | |
Equals | Object | Object(overriden) | |
GetHashCode | Object(overriden) | ||
GetLocalValueEnumerator | DependencyObject | ||
GetValue | DependencyProperty | DependencyObject | |
InvalidateProperty | DependencyProperty | DependencyObject | |
ReadLocalValue | DependencyProperty | DependencyObject | |
SetCurrentValue | DependencyProperty, Object | DependencyObject | |
SetValue | DependencyProperty, Object | DependencyObject | |
SetValue | DependencyPropertyKey, Object | DependencyObject | |
ToString | Object(overriden) | ||
VerifyAccess | DispatcherObject |
MemberwiseClone | Object | ||
OnHeaderStringFormatChanged | String, String | GridViewColumn | |
OnPropertyChanged | DependencyPropertyChangedEventArgs | DependencyObject | |
OnPropertyChanged | PropertyChangedEventArgs | GridViewColumn |
ActualWidth | Double | GridViewColumn | |
CellContentConvertHandler | Func<DataRepositoryItem,Object> | ||
CellTemplate | DataTemplate | GridViewColumn | |
CellTemplateSelector | DataTemplateSelector | GridViewColumn | |
DependencyObjectType | DependencyObjectType | DependencyObject | |
Dispatcher | Dispatcher | DispatcherObject | |
DisplayMemberBinding | BindingBase | GridViewColumn | |
Header | Object | GridViewColumn | |
HeaderContainerStyle | Style | GridViewColumn | |
HeaderStringFormat | String | GridViewColumn | |
HeaderTemplate | DataTemplate | GridViewColumn | |
HeaderTemplateSelector | DataTemplateSelector | GridViewColumn | |
IsSealed | Boolean | DependencyObject | |
| header | String<!– System.String –> | |
| width | Double<!– System.Double –> |
| width | Double<!– System.Double –> | |
| cellContentConverter | Func<DataRepositoryItem,Object><!– System.Func{ThinkGeo.MapSuite.GisEditor.DataRepositoryItem,System.Object} –> |
<!– System.Windows.Threading.DispatcherObject –> Go Back
| key | DependencyPropertyKey<!– System.Windows.DependencyPropertyKey –> |
<!– System.Windows.DependencyObject –> Go Back
| dp | DependencyProperty<!– System.Windows.DependencyProperty –> |
| LocalValueEnumerator<!– System.Windows.LocalValueEnumerator –> |
| dp | DependencyProperty<!– System.Windows.DependencyProperty –> | |
| value | Object<!– System.Object –> |
| key | DependencyPropertyKey<!– System.Windows.DependencyPropertyKey –> | |
| oldHeaderStringFormat | String<!– System.String –> | |
| newHeaderStringFormat | String<!– System.String –> |
<!– System.Windows.Controls.GridViewColumn –> Go Back
| e | DependencyPropertyChangedEventArgs<!– System.Windows.DependencyPropertyChangedEventArgs –> |
| e | PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryGridColumn –> Go Back
| DataTemplate<!– System.Windows.DataTemplate –> |
| DataTemplateSelector<!– System.Windows.Controls.DataTemplateSelector –> |
| DependencyObjectType<!– System.Windows.DependencyObjectType –> |
| Dispatcher<!– System.Windows.Threading.Dispatcher –> |
| BindingBase<!– System.Windows.Data.BindingBase –> |
| Style<!– System.Windows.Style –> |
