thinkgeo.mapsuite.giseditor.datarepositorygridcellconverter
ThinkGeo.MapSuite.GisEditor.DataRepositoryGridCellConverter
<!– Class –>
Public MethodDataRepositoryGridCellConverter
Public MethodConvert Object, Type, Object, CultureInfo
Public MethodConvertBack Object, Type, Object, CultureInfo
Public MethodGetType Object
Public MethodToString Object
Public PropertyCellContentConvertHandler Func<DataRepositoryItem,Object>
DataRepositoryGridCellConverter()
Name Type Description
Go Back
Convert(Object, Type, Object, CultureInfo)
Return Type Description
Object<!– System.Object –>
value Object<!– System.Object –>
targetType Type<!– System.Type –>
parameter Object<!– System.Object –>
culture CultureInfo<!– System.Globalization.CultureInfo –>
<!– ThinkGeo.MapSuite.GisEditor.DataRepositoryGridCellConverter –> Go Back
ConvertBack(Object, Type, Object, CultureInfo)
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
String<!– System.String –>
Void<!– System.Void –>
Return Type
Func<DataRepositoryItem,Object><!– System.Func{ThinkGeo.MapSuite.GisEditor.DataRepositoryItem,System.Object} –>
thinkgeo.mapsuite.giseditor.datarepositorygridcellconverter.txt · Last modified: 2017/03/16 21:59 (external edit)
