thinkgeo.mapsuite.desktopedition.vertexremovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs
Provides data for the VertexRemoving event.
      • ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs
VertexRemovingEditInteractiveOverlayEventArgs()
VertexRemovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#VertexRemovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29
  • cancel
    • Description:This parameter specifies the cancel property.
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specifies the affectedVertex feature property.
  • removingVertex
    • Type:Vertex
    • Description:This parameter specifies the target vertex to be removed.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
AffectedVertexFeature
This property gets or sets the Feature from which the vertex will be removed.
RemovingVertex
This property gets or sets the vertex to be removed.
Cancel
This property gets or sets whether or not the action will be canceled.
thinkgeo.mapsuite.desktopedition.vertexremovingeditinteractiveoverlayeventargs.1442909611.txt.gz · Last modified: 2015/09/22 08:13 by admin
