<!– Class –> Provides data for the VertexRemoving event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs
VertexRemovingEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexRemovingEditInteractiveOverlayEventArgs | Boolean, Feature, Vertex | This is the commonly used constructor. |
AffectedVertexFeature | Feature | This property gets or sets the Feature from which the vertex will be removed. | |
Cancel | Boolean | This property gets or sets whether or not the action will be canceled. | |
RemovingVertex | Vertex | This property gets or sets the vertex to be removed. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#VertexRemovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#VertexRemovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29</a>
| cancel | Boolean<!– System.Boolean –> | This parameter specifies the cancel property. |
| affectedVertexFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the affectedVertex feature property. |
| removingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specifies the target vertex to be removed. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#AffectedVertexFeature” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#AffectedVertexFeature</a>
<!– ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Cancel</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#RemovingVertex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#RemovingVertex</a>
