thinkgeo.mapsuite.desktopedition.vertexremovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs
Provides data for the VertexRemoved event.
      • ThinkGeo.MapSuite.DesktopEdition.VertexRemovedEditInteractiveOverlayEventArgs
VertexRemovedEditInteractiveOverlayEventArgs()
VertexRemovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specifies the affectedVertex feature property.
  • removedVertex
    • Type:Vertex
    • Description:This parameter specifies the target vertex removed.
AffectedVertexFeature
This property gets or sets the Feature from which the vertex was removed.
RemovedVertex
This property gets or sets the vertex removed.
thinkgeo.mapsuite.desktopedition.vertexremovededitinteractiveoverlayeventargs.1442545513.txt.gz · Last modified: 2015/09/18 03:05 by admin
