<!– Class –> Provides data for the VertexMoving event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs
VertexMovingEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexMovingEditInteractiveOverlayEventArgs | Boolean, Feature, Vertex | This is the commonly used constructor. | |
VertexMovingEditInteractiveOverlayEventArgs | Boolean, Feature, Vertex, Vertex | This is the commonly used constructor. |
AffectedVertexFeature | Feature | This property gets or sets the Feature whose vertex will be moved. | |
Cancel | Boolean | This property gets or sets whether or not the action will be canceled. | |
MovingVertex | Vertex | This property gets or sets the vertex to be moved. | |
TargetVertex | Vertex | This property gets or sets the target control point to moved. |
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29</a>
cancel | Boolean<!– System.Boolean –> | This parameter specifies the cancel property. |
affectedVertexFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the affectedVertex feature property. |
movingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specifies the target vertex to be moved. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.2C_Vertex.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.2C_Vertex.29</a>
targetVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specifies the target vertex to be moved. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#ToString.28.29</a>
String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#AffectedVertexFeature” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#AffectedVertexFeature</a>
Return Type |
<!– ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Cancel</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MovingVertex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MovingVertex</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#TargetVertex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#TargetVertex</a>
Return Type |
