thinkgeo.mapsuite.desktopedition.vertexaddingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs
Provides data for the VertexAdding event.
      • ThinkGeo.MapSuite.DesktopEdition.VertexAddingTrackInteractiveOverlayEventArgs
VertexAddingTrackInteractiveOverlayEventArgs()
VertexAddingTrackInteractiveOverlayEventArgs(Vertex,Feature,Boolean)
  • addingVertex
    • Type:Vertex
    • Description:This parameter specifies the vertex that is going to be added.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specifies the feature that the vertex will be added to when tracking shape.
  • cancel
    • Description:This parameter specifies the cancel property.
Cancel
This property gets or sets whether the action will be canceled or not.
AddingVertex
This property gets or sets the feature that the vertex will be added to when tracking shape.
AffectedFeature
This property gets or sets the Feature that the vertex will be added to.
thinkgeo.mapsuite.desktopedition.vertexaddingtrackinteractiveoverlayeventargs.1442545504.txt.gz · Last modified: 2015/09/18 03:05 by admin
