thinkgeo.mapsuite.desktopedition.vertexaddingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs
Provides data for the VertexAdding event.
      • ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs
VertexAddingEditInteractiveOverlayEventArgs()
VertexAddingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#VertexAddingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29
  • cancel
    • Description:This parameter specifies the cancel property.
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specifies the affectedVertex feature property.
  • addingVertex
    • Type:Vertex
    • Description:This parameter specifies the target vertex to be added.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexAddingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
AffectedVertexFeature
This property gets or sets the Feature the vertex will be added to.
AddingVertex
This property gets or sets the vertex to be added.
Cancel
This property gets or sets whether or not the action will be canceled.
thinkgeo.mapsuite.desktopedition.vertexaddingeditinteractiveoverlayeventargs.1442909600.txt.gz · Last modified: 2015/09/22 08:13 by admin
