thinkgeo.mapsuite.desktopedition.vertexaddedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs
Provides data for the VertexAdded event.
      • ThinkGeo.MapSuite.DesktopEdition.VertexAddedTrackInteractiveOverlayEventArgs
VertexAddedTrackInteractiveOverlayEventArgs()
VertexAddedTrackInteractiveOverlayEventArgs(Vertex,Feature)
  • addedVertex
    • Type:Vertex
    • Description:This parameter specifies the vertex that was added.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specifies the feature that the vertex was added to when tracking shape.
AddedVertex
This property gets or sets the vertex added.
AffectedFeature
This property gets or sets the Feature that the vertex was added to.
thinkgeo.mapsuite.desktopedition.vertexaddedtrackinteractiveoverlayeventargs.1442545499.txt.gz · Last modified: 2015/09/18 03:04 by admin
