thinkgeo.mapsuite.desktopedition.vertexaddededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.VertexAddedEditInteractiveOverlayEventArgs
Provides data for the VertexAdded event.
      • ThinkGeo.MapSuite.DesktopEdition.VertexAddedEditInteractiveOverlayEventArgs
VertexAddedEditInteractiveOverlayEventArgs()
VertexAddedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specifies the affectedVertex feature property.
  • addedVertex
    • Type:Vertex
    • Description:This parameter specifies the target vertex added.
AffectedVertexFeature
This property gets or sets the Feature the vertex was added to.
AddedVertex
This property gets or sets the vertex added.
thinkgeo.mapsuite.desktopedition.vertexaddededitinteractiveoverlayeventargs.1442545497.txt.gz · Last modified: 2015/09/18 03:04 by admin
