thinkgeo.mapsuite.desktopedition.tiledwmsoverlay
ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay
This class is used in Desktop Edition to access the WMS Server.
    • ThinkGeo.MapSuite.DesktopEdition.Overlay
      • ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay
TiledWmsOverlay()
  • This is the constructor of the class.
  • If you use this constructor, you must set the properties manually before use, otherwise it will use their default values.
TiledWmsOverlay(Uri)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#TiledWmsOverlay.28Uri.29
  • serverUri
    • Type:Uri
    • Description:The URI of WMS Serer you are consuming
TiledWmsOverlay(Uri,WebProxy)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#TiledWmsOverlay.28Uri.2C_WebProxy.29
  • serverUri
    • Type:Uri
  • webProxy
    • Type:WebProxy
    • Description:Proxy to use for the WMS Server.
TiledWmsOverlay(Uri,String,String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#TiledWmsOverlay.28Uri.2C_String.2C_String.29
  • serverUri
    • Type:Uri
  • clientId
    • Description:The clientId for the WMS Server.
  • privateKey
    • Description:The privateKey for the WMS Server.
TiledWmsOverlay(Uri,WebProxy,String,String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#TiledWmsOverlay.28Uri.2C_WebProxy.2C_String.2C_String.29
  • serverUri
    • Type:Uri
  • webProxy
    • Type:WebProxy
  • clientId
  • privateKey
ClearCache()
  • This method will clear the cache for the Overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#ClearCache.28.29
Refresh(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#Refresh.28GeoCanvas.2C_RectangleShape.29
DrawPreview(GeoCanvas)
  • This method will be used to draw preview tiles to the canvas.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#DrawPreview.28GeoCanvas.29
  • Description:The tile existing type, which indicates whether any tiles exist.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object to draw on.
Draw(GeoCanvas)
  • This method draws the Overlay.
  • This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • canvas
    • Type:GeoCanvas
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#GetType.28.29
DrawCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#DrawCore.28GeoCanvas.29
  • This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#DrawExceptionCore.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
    • Description:The target canvas to draw the layer.
  • e
    • Type:Exception
    • Description:The exception thrown when layer.Draw().
OnSendingWebRequest(SendingWebRequestEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#OnSendingWebRequest.28SendingWebRequestEventArgs.29
OnSentWebRequest(SentWebRequestEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29
OnDrawing(DrawingOverlayEventArgs)
  • This event will be fired before Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#OnDrawing.28DrawingOverlayEventArgs.29
OnDrawn(DrawnOverlayEventArgs)
  • This event will be fired after Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#OnDrawn.28DrawnOverlayEventArgs.29
RefreshCore(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#RefreshCore.28GeoCanvas.2C_RectangleShape.29
DrawPreviewCore(GeoCanvas)
  • This is the core method of DrawPreview which is intended to be overridden by its concrete sub class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#DrawPreviewCore.28GeoCanvas.29
  • canvas
    • Type:GeoCanvas
sBM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#DrawAttributionCore.28GeoCanvas.29
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
  • This method will draw on the canvas when an exception occurs during the drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#DrawException.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
  • e
    • Type:Exception
    • Description:This parameter is the exception that is occurring.
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TiledWmsOverlay#MemberwiseClone.28.29
ClientId
  • Gets or sets a value that is your Client Id.
ActiveLayerNames
  • This property represents the available layers that can be requested from the client and shown on the map.
  • When requesting a map, a client may specify the layers to be shown on the map.
  • Type:Collection<String>
ActiveStyleNames
  • This property represents the available styles that can be requested from the client and shown on the map.
  • When requesting a map, a client may specify the styles to be shown on the map.
  • This property specifies a dictionary used to update the request sent from the client to the WMS server.
WebProxy
  • This property gets or sets the proxy used for requesting a Web Response.
  • Type:Uri
AxisOrder
  • Type:TimeSpan
Attribution
IsBase
  • Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false.
IsVisible
  • Gets or sets a value that indicates whether the overlay is visible on the map.
PreviewTileCache
  • This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set.
DrawingTime
  • This property gets the last drawing time for the Overlay.
  • We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
  • Type:TimeSpan
AutoRefreshInterval
  • Type:TimeSpan
rxM=
SendingWebRequest
Event Arguments:SentWebRequestEventArgs
Drawing
  • This event will be fired before the Overlay is drawn.
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution
Event Arguments:RequestedDrawingOverlayEventArgs
RequestingDrawing
Event Arguments:RequestingDrawingOverlayEventArgs
thinkgeo.mapsuite.desktopedition.tiledwmsoverlay.1442966515.txt.gz · Last modified: 2015/09/23 00:01 by admin
