thinkgeo.mapsuite.desktopedition.mousemovedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MouseMovedTrackInteractiveOverlayEventArgs
<!– Class –> Provides data for the MouseMoved event.
Public MethodMouseMovedTrackInteractiveOverlayEventArgs This is the default constructor of this parameter.
Public MethodMouseMovedTrackInteractiveOverlayEventArgs Vertex, Feature This is the commonly used constructor.
Public MethodGetType Object
Public MethodToString Object
Public PropertyAffectedFeature Feature This property gets or sets the Feature to be affected.
Public PropertyMovedVertex Vertex This property gets or sets the vertex to be moved.
MouseMovedTrackInteractiveOverlayEventArgs()
Name Type Description
Go Back
MouseMovedTrackInteractiveOverlayEventArgs(Vertex, Feature)
movedVertex Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> This parameter specifies the target vertex to be moved.
affectedFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter specifies the affected feature.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
AffectedFeature
Return Type
<!– ThinkGeo.MapSuite.DesktopEdition.MouseMovedTrackInteractiveOverlayEventArgs –> Go Back
MovedVertex
Return Type
thinkgeo.mapsuite.desktopedition.mousemovedtrackinteractiveoverlayeventargs.1440040130.txt.gz · Last modified: 2015/09/18 03:03 (external edit)
