thinkgeo.mapsuite.desktopedition.markeroverlay
Table of Contents
ThinkGeo.MapSuite.DesktopEdition.MarkerOverlay
<!– Class –>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerOverlay</a>
Protected MethodMarkerOverlay
Protected MethodDrawAttributionCore GeoCanvas Overlay
Protected MethodDrawCore GeoCanvas Overlay(overriden)
Protected MethodDrawException GeoCanvas, Exception Overlay This method will draw on the canvas when an exception occurs during the drawing process.
Protected MethodDrawExceptionCore GeoCanvas, Exception Overlay This method is the Core method of DrawException, which can be overridden if you want to change its logic. This method will draw on the canvas when an exception occurs during drawing process.
Protected MethodDrawPreviewCore GeoCanvas Overlay This is the core method of DrawPreview which is intended to be overridden by its concrete sub class.
Protected MethodGetMarkersForDrawingCore RectangleShape
Protected MethodOnDrawing DrawingOverlayEventArgs Overlay This event will be fired before Overlay is drawn.
Protected MethodOnDrawingAttribution DrawingAttributionOverlayEventArgs Overlay
Protected MethodOnDrawn DrawnOverlayEventArgs Overlay This event will be fired after Overlay is drawn.
Protected MethodOnDrawnAttribution DrawnAttributionOverlayEventArgs Overlay
Protected MethodOnRequestedDrawing RequestedDrawingOverlayEventArgs Overlay
Protected MethodOnRequestingDrawing RequestingDrawingOverlayEventArgs Overlay
Protected MethodRefreshCore GeoCanvas, RectangleShape Overlay
Public PropertyAttribution String Overlay
Public PropertyAutoRefreshInterval TimeSpan Overlay
Public PropertyDrawingExceptionMode DrawingExceptionMode Overlay This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
Public PropertyDrawingTime TimeSpan Overlay This property gets the last drawing time for the Overlay.
Public PropertyIsBase Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false.
Public PropertyIsEmpty Boolean Overlay This property can be overridden by its base class. If it is not overridden, its default return value will be false. If this property is empty, we can skip drawing to achieve better performance.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyLock OverlayLock Overlay This property gets the OverlayLock object.
Public PropertyMapControl WinformsMap
Public PropertyName String Overlay Gets or sets the name of the overlay, which can be used to represent a specific overlay.
Public PropertyPreviewTileCache BitmapTileCache Overlay This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set.
Public PropertyTileCache BitmapTileCache Overlay This property gets or sets the TileCache used for the overlay.
MarkerOverlay()
Name Type Description
Go Back
Draw(GeoCanvas)
This method draws the Overlay.
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided.As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Return Type Description
Void<!– System.Void –>
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object to draw on.
<!– ThinkGeo.MapSuite.DesktopEdition.Overlay –> Go Back
DrawPreview(GeoCanvas)
This method will be used to draw preview tiles to the canvas.
TilesExistingType<!– ThinkGeo.MapSuite.DesktopEdition.TilesExistingType –> The tile existing type, which indicates whether any tiles exist.
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetMarkersForDrawing(RectangleShape)
GeoCollection<Marker><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.DesktopEdition.Marker} –>
boundingBox RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
<!– ThinkGeo.MapSuite.DesktopEdition.MarkerOverlay –> Go Back
Type<!– System.Type –>
Refresh(GeoCanvas, RectangleShape)
extent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
bufferTime TimeSpan<!– System.TimeSpan –>
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
RequestDrawing(RectangleShape, TimeSpan)
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(TimeSpan)
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing()
String<!– System.String –>
DrawAttributionCore(GeoCanvas)
DrawCore(GeoCanvas)
<!– ThinkGeo.MapSuite.DesktopEdition.Overlay(overriden) –> Go Back
DrawException(GeoCanvas, Exception)
e Exception<!– System.Exception –> This parameter is the exception that is occurring.
DrawExceptionCore(GeoCanvas, Exception)
DrawPreviewCore(GeoCanvas)
GetMarkersForDrawingCore(RectangleShape)
OnDrawing(DrawingOverlayEventArgs)
e DrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawingOverlayEventArgs –> The OverlayDrawingEventArgs passed for the event raised.
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
args DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawingAttributionOverlayEventArgs –>
OnDrawn(DrawnOverlayEventArgs)
e DrawnOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs –> The OverlayDrawnEventArgs passed for the event raised.
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
args DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawnAttributionOverlayEventArgs –>
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
eventArgs RequestedDrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.RequestedDrawingOverlayEventArgs –>
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
eventArgs RequestingDrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.RequestingDrawingOverlayEventArgs –>
RefreshCore(GeoCanvas, RectangleShape)
Attribution
Return Type
AutoRefreshInterval
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingTime
We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
Return Type
IsBase
Return Type
IsEmpty
Return Type
IsVisible
Return Type
Lock
Return Type
OverlayLock<!– ThinkGeo.MapSuite.DesktopEdition.OverlayLock –>
MapControl
Return Type
WinformsMap<!– ThinkGeo.MapSuite.DesktopEdition.WinformsMap –>
Return Type
PreviewTileCache
Return Type
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –>
TileCache
The TileCache system is always used for better performance, especially in the case where your application tiles can be pregenerated.
Return Type
Drawing
This event will be fired before the Overlay is drawn.
Event Arguments
Event Arguments
DrawingAttribution
Event Arguments
Event Arguments
Drawn
This event will be fired after the Overlay is drawn.
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
NOTOC DesktopEdition ThinkGeo.MapSuite.DesktopEdition UpdateDocumentation
thinkgeo.mapsuite.desktopedition.markeroverlay.1440040130.txt.gz · Last modified: 2015/09/18 03:03 (external edit)
