thinkgeo.mapsuite.desktopedition.mapmousedowninteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs
<!– Class –> Provides data for the MapMouseDown event.
Public MethodMapMouseDownInteractiveOverlayEventArgs This is the default constructor of this parameter.
Public MethodMapMouseDownInteractiveOverlayEventArgs InteractionArguments This is the commonly used constructor.
Public MethodGetType Object
Public MethodToString Object
Public PropertyInteractionArguments InteractionArguments This property gets the interaction arguments for the event args.
MapMouseDownInteractiveOverlayEventArgs()
Name Type Description
Go Back
MapMouseDownInteractiveOverlayEventArgs(InteractionArguments)
interactionArguments InteractionArguments<!– ThinkGeo.MapSuite.DesktopEdition.InteractionArguments –> This parameter specified the interaction arguments to construct the class.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Return Type
<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs –> Go Back
thinkgeo.mapsuite.desktopedition.mapmousedowninteractiveoverlayeventargs.1440040130.txt.gz · Last modified: 2015/09/18 03:03 (external edit)
