thinkgeo.mapsuite.desktopedition.layeroverlay
ThinkGeo.MapSuite.DesktopEdition.LayerOverlay
: This class represents a group of layers; each layer can be of any layer type.
    • ThinkGeo.MapSuite.DesktopEdition.Overlay
      • ThinkGeo.MapSuite.DesktopEdition.LayerOverlay
LayerOverlay()
  • Initialize an instance of the LayerOverlay class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#LayerOverlay.28.29
Refresh(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#Refresh.28GeoCanvas.2C_RectangleShape.29
DrawPreview(GeoCanvas)
  • This method will be used to draw preview tiles to the canvas.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#DrawPreview.28GeoCanvas.29
  • Description:The tile existing type, which indicates whether any tiles exist.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object to draw on.
Draw(GeoCanvas)
  • This method draws the Overlay.
  • This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • canvas
    • Type:GeoCanvas
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#GetType.28.29
RefreshCore(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#RefreshCore.28GeoCanvas.2C_RectangleShape.29
DrawCore(GeoCanvas)
  • Draw all of the layers to the image object using the parameters specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#DrawCore.28GeoCanvas.29
  • canvas
    • Type:GeoCanvas
    • Description:The GeoCanvas object that the layers will draw on.
OnDrawing(DrawingOverlayEventArgs)
  • This event will be fired before Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#OnDrawing.28DrawingOverlayEventArgs.29
OnDrawn(DrawnOverlayEventArgs)
  • This event will be fired after Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#OnDrawn.28DrawnOverlayEventArgs.29
DrawPreviewCore(GeoCanvas)
  • This is the core method of DrawPreview which is intended to be overridden by its concrete sub class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#DrawPreviewCore.28GeoCanvas.29
  • canvas
    • Type:GeoCanvas
sBM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#DrawAttributionCore.28GeoCanvas.29
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
  • This method will draw on the canvas when an exception occurs during the drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#DrawException.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
  • e
    • Type:Exception
    • Description:This parameter is the exception that is occurring.
  • This method is the Core method of DrawException, which can be overridden if you want to change its logic. This method will draw on the canvas when an exception occurs during drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#DrawExceptionCore.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
  • e
    • Type:Exception
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#MemberwiseClone.28.29
Layers
Gets a GeoCollection that contains the layers that will draw on the image.
The <strong>Layers</strong> property holds all of the layers that are used by the <strong>Draw</strong> method. The Draw method loops through all layers to filter out features and draw on the image with the specified styles.
If the layer count is zero, returns true. Otherwise, returns false.
Attribution
Lock
This property gets the OverlayLock object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#Lock
IsBase
Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#IsBase
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#DrawingExceptionMode
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#IsVisible
Gets or sets the name of the overlay, which can be used to represent a specific overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#Name
TileCache
This property gets or sets the TileCache used for the overlay.
The TileCache system is always used for better performance, especially in the case where your application tiles can be pregenerated.
PreviewTileCache
This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#PreviewTileCache
DrawingTime
This property gets the last drawing time for the Overlay.
We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
  • Type:TimeSpan
AutoRefreshInterval
  • Type:TimeSpan
rxM=
Drawing This event will be fired before the Overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#OnDrawing.28DrawingOverlayEventArgs.29
Event Arguments:DrawingOverlayEventArgs
Drawn This event will be fired after the Overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.LayerOverlay#OnDrawn.28DrawnOverlayEventArgs.29
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution N/A
Event Arguments:RequestedDrawingOverlayEventArgs
RequestingDrawing N/A
Event Arguments:RequestingDrawingOverlayEventArgs
thinkgeo.mapsuite.desktopedition.layeroverlay.1442909485.txt.gz · Last modified: 2015/09/22 08:11 by admin
