<!– Class –> This class encapsulates the information and simple method for key events interative actions.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments</a>
*System.Object **ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments
![]() | This is the default constructor of this parameter. | ||
![]() | String, Boolean, Boolean, Boolean | This is the constructor of this parameter by passing parameters. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | RectangleShape | This property gets or sets the current extent used in the MapControl. | |
![]() | Double | This property gets or sets the scale in the current status. | |
![]() | Boolean | Gets and sets a value indicating whether the ALT key was pressed. true if the ALT key was pressed; otherwise, false. | |
![]() | Boolean | Gets and sets a value indicating whether the CTRL key was pressed. true if the CTRL key was pressed; otherwise, false. | |
![]() | Boolean | Gets a value indicating whether the SHIFT key was pressed. true if the SHIFT key was pressed; otherwise, false. | |
![]() | String | This property gets and sets string indicates the key used in the key events. | |
![]() | ZoomLevelSet | This property gets or sets the ZoomLevelSet used in the Map Control. | |
![]() | ZoomLevelSnappingMode | This property gets or sets the ZoomLevelSnappingMode used in the Map Control. |
If you use this constructor, you have to set its properties manually before use.
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#KeyEventInteractionArguments.28String.2C_Boolean.2C_Boolean.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#KeyEventInteractionArguments.28String.2C_Boolean.2C_Boolean.2C_Boolean.29</a>
key | String<!– System.String –> | This parameters indicates the key string used in the events. |
isCtrlKeyPressed | Boolean<!– System.Boolean –> | This parameter indicates the CTRIL key is pressed or not. |
isShiftKeyPressed | Boolean<!– System.Boolean –> | This parameter indicates the SHIFT key is pressed or not. |
isAltKeyPressed | Boolean<!– System.Boolean –> | This parameter indicates the ALT key is pressed or not. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#CurrentExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#CurrentExtent</a>
Return Type |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#CurrentScale” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#CurrentScale</a>
Return Type |
Double<!– System.Double –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#IsAltKeyPressed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#IsAltKeyPressed</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#IsCtrlKeyPressed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#IsCtrlKeyPressed</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#IsShiftKeyPressed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#IsShiftKeyPressed</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#ZoomLevelSet” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#ZoomLevelSet</a>
Return Type |
ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#ZoomLevelSnapping” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments#ZoomLevelSnapping</a>
Return Type |
ZoomLevelSnappingMode<!– ThinkGeo.MapSuite.DesktopEdition.ZoomLevelSnappingMode –> |
