thinkgeo.mapsuite.desktopedition.interactiveresult
ThinkGeo.MapSuite.DesktopEdition.InteractiveResult
This class specifies the InterativeResult when dealing with the Interative method in InterativeOverlay.
    • ThinkGeo.MapSuite.DesktopEdition.InteractiveResult
InteractiveResult()
InteractiveResult(InteractiveOverlayDrawType,ProcessOtherOverlaysMode)
  • interactiveOverlayDrawType
    • Description:This parameter specifies the interactiveOverlayDrawType used to construct the class.
  • processOtherOverlays
    • Description:This parameter specifies the processOtherOverlays used to construct the class.
DrawThisOverlay
This property gets and sets the DrawThisOverlay type, which indicates whether to draw this overlay or not.
This property gets and sets the DrawThisOverlay type, which indicates how to process other overlays.
NewCurrentExtent
This property gets and sets the new current extent if the interative action affects the extent.
thinkgeo.mapsuite.desktopedition.interactiveresult.1442545366.txt.gz · Last modified: 2015/09/18 03:02 by admin
