thinkgeo.mapsuite.desktopedition.interactionarguments
ThinkGeo.MapSuite.DesktopEdition.InteractionArguments
This class encapsulates the information and simple method for interative actions.
    • ThinkGeo.MapSuite.DesktopEdition.InteractionArguments
InteractionArguments()
  • If you use this constructor, you have to set its properties manually before use.
  • Overrides the ToString API for an object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#ToString.28.29
  • Description:Returns a string to mark this instance, making it easy to read its properties.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#MemberwiseClone.28.29
ScreenX
This property gets or sets the screen X position.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#ScreenX
  • Type:Single
ScreenY
This property gets or sets the screen Y position.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#ScreenY
  • Type:Single
WorldX
This property gets or sets the world X position.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#WorldX
WorldY
This property gets or sets the world Y position.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#WorldY
MouseButton
This property gets or sets the MouseButton used for the interative action.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#MouseButton
CurrentExtent
This property gets or sets the current extent used in the MapControl.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#CurrentExtent
SearchingTolerance
This property gets or sets the search tolearance for tracking and editing.
MapWidth
This property gets or sets the width for the Map Control.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#MapWidth
MapHeight
This property gets or sets the height for the Map Control.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#MapHeight
MapUnit
This property gets or sets the geographic unit for the Map Control.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#MapUnit
ZoomLevelSet
This property gets or sets the ZoomLevelSet used in the Map Control.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#ZoomLevelSet
ZoomLevelSnapping
This property gets or sets the ZoomLevelSnappingMode used in the Map Control.
MouseWheelDelta
This property gets or sets the mouse wheel delta used in the MouseWheel method in InterativeOverlay.
Scale
This property gets or sets the scale in the current status.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#Scale
ExtendedProperties
This property gets the extended properties in the current status.
  • Type:Dictionary<String,Object>
thinkgeo.mapsuite.desktopedition.interactionarguments.1442909476.txt.gz · Last modified: 2015/09/22 08:11 by admin
