thinkgeo.mapsuite.desktopedition.googlemapsoverlay
ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay
This class represents the Overlay used to display a Google Map.
    • ThinkGeo.MapSuite.DesktopEdition.Overlay
      • ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay
GoogleMapsOverlay()
  • This is the constructor of the class.
  • If you use this constructor, you have to set the properties manually before use, otherwise it will use their default values.
GoogleMapsOverlay(String,String,String)
  • This is the constructor the for the class.
  • This constructor initializes a new layer and assgin a license key.
  • cacheDirectory
    • Description:The cacheDirectory for the GoogleMapsOverlay.
  • clientId
    • Description:The clientId for the GoogleMapsOverlay.
  • privateKey
    • Description:The privateKey for the GoogleMapsOverlay.
GoogleMapsOverlay(String,String,String,WebProxy)
  • cacheDirectory
  • clientId
  • privateKey
  • webProxy
    • Type:WebProxy
GetPictureFormatString()
  • This method gets a string that represents the picture format from Google Maps.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetPictureFormatString.28.29
  • Description:Returns a string representing the picture format from GoogleMaps.
Dispose()
  • Releases the unmanaged resources.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Dispose.28.29
ClearCache()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ClearCache.28.29
ClearCache(String,TimeSpan,Double)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ClearCache.28String.2C_TimeSpan.2C_Double.29
  • cacheFolder
  • tileExpiration
    • Type:TimeSpan
  • maxSizeInMegabytes
Refresh(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Refresh.28GeoCanvas.2C_RectangleShape.29
DrawPreview(GeoCanvas)
  • This method will be used to draw preview tiles to the canvas.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawPreview.28GeoCanvas.29
  • Description:The tile existing type, which indicates whether any tiles exist.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object to draw on.
Draw(GeoCanvas)
  • This method draws the Overlay.
  • This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • canvas
    • Type:GeoCanvas
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetType.28.29
DrawCore(GeoCanvas)
  • This method draws the GoogleMapsOverlay.
  • This method draws the representation of the overlay based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
OnSendingWebRequest(SendingWebRequestEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnSendingWebRequest.28SendingWebRequestEventArgs.29
OnSentWebRequest(SentWebRequestEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29
OnDrawing(DrawingOverlayEventArgs)
  • This event will be fired before Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawing.28DrawingOverlayEventArgs.29
OnDrawn(DrawnOverlayEventArgs)
  • This event will be fired after Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawn.28DrawnOverlayEventArgs.29
RefreshCore(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#RefreshCore.28GeoCanvas.2C_RectangleShape.29
DrawPreviewCore(GeoCanvas)
  • This is the core method of DrawPreview which is intended to be overridden by its concrete sub class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawPreviewCore.28GeoCanvas.29
  • canvas
    • Type:GeoCanvas
sBM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawAttributionCore.28GeoCanvas.29
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
  • This method will draw on the canvas when an exception occurs during the drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawException.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
  • e
    • Type:Exception
    • Description:This parameter is the exception that is occurring.
  • This method is the Core method of DrawException, which can be overridden if you want to change its logic. This method will draw on the canvas when an exception occurs during drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawExceptionCore.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
  • e
    • Type:Exception
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#MemberwiseClone.28.29
TileMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TileMode
TimeoutInSeconds
Gets or sets a value represents the request timeout from the GoogleMaps server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TimeoutInSeconds
MapType
This property gets or sets the map types available from Google Maps.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#MapType
ClientId
Gets or sets a value to access the special features of Google Maps API Premier, you must provide a client ID when accessing any of the Premier API libraries or services. When registering for Google Maps API Premier, you will receive this client ID from Google Enterprise Support. All client IDs begin with a gme- prefix.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ClientId
PrivateKey
Gets or sets a value that is unique to your client ID, please keep your key secure.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#PrivateKey
WebProxy
This property gets or sets the proxy used for requesting a Web Response.
  • Type:WebProxy
TileCache
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#PreviewTileCache
ProjectionFromSphericalMercator
ProjectedTileCache
TileExpiration
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TileExpiration
  • Type:TimeSpan
MaxCacheSizeInMegabytes
Attribution
Lock
This property gets the OverlayLock object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Lock
IsBase
Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsBase
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsVisible
Gets or sets the name of the overlay, which can be used to represent a specific overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Name
PreviewTileCache
This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set.
IsEmpty
This property can be overridden by its base class. If it is not overridden, its default return value will be false. If this property is empty, we can skip drawing to achieve better performance.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsEmpty
DrawingTime
This property gets the last drawing time for the Overlay.
We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
  • Type:TimeSpan
AutoRefreshInterval
  • Type:TimeSpan
rxM=
SendingWebRequest N/A
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29
Event Arguments:SentWebRequestEventArgs
Drawing This event will be fired before the Overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawing.28DrawingOverlayEventArgs.29
Event Arguments:DrawingOverlayEventArgs
Drawn This event will be fired after the Overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawn.28DrawnOverlayEventArgs.29
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution N/A
Event Arguments:RequestedDrawingOverlayEventArgs
RequestingDrawing N/A
Event Arguments:RequestingDrawingOverlayEventArgs
thinkgeo.mapsuite.desktopedition.googlemapsoverlay.1442909472.txt.gz · Last modified: 2015/09/22 08:11 by admin
