This class represents the Overlay used to display a Google Map.
If you use this constructor, you have to set the properties manually before use, otherwise it will use their default values.
This constructor initializes a new layer and assgin a license key.
GoogleMapsOverlay(String,String,String,WebProxy)
This is the constructor the for the class.
This method gets a string that represents the picture format from Google Maps.
Refresh(GeoCanvas,RectangleShape)
This method draws the representation of the overlay based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
OnSendingWebRequest(SendingWebRequestEventArgs)
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
Gets or sets a value represents the request timeout from the GoogleMaps server.
Gets or sets a value to access the special features of Google Maps API Premier, you must provide a client ID when accessing any of the Premier API libraries or services. When registering for Google Maps API Premier, you will receive this client ID from Google Enterprise Support. All client IDs begin with a gme- prefix.
Gets or sets a value that is unique to your client ID, please keep your key secure.
Event Arguments:RequestingDrawingOverlayEventArgs
