thinkgeo.mapsuite.desktopedition.featurerotatededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs
Provides data for the FeatureRotated event.
      • ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs
FeatureRotatedEditInteractiveOverlayEventArgs()
FeatureRotatedEditInteractiveOverlayEventArgs(Feature)
  • rotatedFeature
    • Type:Feature
    • Description:This parameter specifies the feature rotated.
RotatedFeature
This property gets or sets the Feature rotated.
thinkgeo.mapsuite.desktopedition.featurerotatededitinteractiveoverlayeventargs.1442545349.txt.gz · Last modified: 2015/09/18 03:02 by admin
