thinkgeo.mapsuite.desktopedition.featurerotatededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs
<!– Class –> Provides data for the FeatureRotated event.
Public MethodFeatureRotatedEditInteractiveOverlayEventArgs This is the default constructor of this parameter.
Public MethodFeatureRotatedEditInteractiveOverlayEventArgs Feature This is the commonly used constructor.
Public MethodGetType Object
Public MethodToString Object
Public PropertyRotatedFeature Feature This property gets or sets the Feature rotated.
FeatureRotatedEditInteractiveOverlayEventArgs()
Name Type Description
Go Back
FeatureRotatedEditInteractiveOverlayEventArgs(Feature)
rotatedFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter specifies the feature rotated.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
RotatedFeature
Return Type
<!– ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs –> Go Back
thinkgeo.mapsuite.desktopedition.featurerotatededitinteractiveoverlayeventargs.1440040130.txt.gz · Last modified: 2015/09/18 03:02 (external edit)
