thinkgeo.mapsuite.core.xmlserializationformatter
ThinkGeo.MapSuite.Core.XmlSerializationFormatter
article_rating
<!– Class –>
Public MethodXmlSerializationFormatter
Public MethodGetType Object
Public MethodLoad Stream GeoSerializationFormatter
Public MethodSave GeoSerializationNode, Stream GeoSerializationFormatter
Public MethodToString Object
Protected MethodLoadCore Stream GeoSerializationFormatter(overriden)
Protected MethodSaveCore GeoSerializationNode, Stream GeoSerializationFormatter(overriden)
XmlSerializationFormatter()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Load(Stream)
GeoSerializationNode<!– ThinkGeo.MapSuite.Core.GeoSerializationNode –>
stream Stream<!– System.IO.Stream –>
<!– ThinkGeo.MapSuite.Core.GeoSerializationFormatter –> Go Back
Save(GeoSerializationNode, Stream)
Void<!– System.Void –>
node GeoSerializationNode<!– ThinkGeo.MapSuite.Core.GeoSerializationNode –>
String<!– System.String –>
LoadCore(Stream)
<!– ThinkGeo.MapSuite.Core.GeoSerializationFormatter(overriden) –> Go Back
SaveCore(GeoSerializationNode, Stream)
thinkgeo.mapsuite.core.xmlserializationformatter.txt · Last modified: 2017/03/16 21:59 (external edit)
