thinkgeo.mapsuite.core.valuestyle
ThinkGeo.MapSuite.Core.ValueStyle
This class allows you to match a value with data in the feature to determine how to draw that feature.
ValueStyle
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is a constructor for the class.
ValueStyle
  • Parameters:String,Collection<ValueItem>
  • DeclaringType:N/A
  • Summary:This is a constructor for this class.
CloneDeep
  • Parameters:N/A
  • DeclaringType:Style
  • Summary:N/A
Draw
Draw
DrawSample
DrawSample
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetRequiredColumnNames
  • Parameters:N/A
  • Summary:N/A
GetType
  • Parameters:N/A
  • Summary:N/A
SaveStyle
  • Parameters:String
  • Summary:N/A
SaveStyle
  • Parameters:Stream
  • Summary:N/A
ToString
  • Parameters:N/A
  • Summary:N/A
CloneDeepCore
  • Parameters:N/A
  • Summary:N/A
DrawCore
DrawSampleCore
Finalize
  • Parameters:N/A
  • Summary:N/A
GetRequiredColumnNamesCore
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This method returns the column data for each feature that is required for the style to properly draw.
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
ColumnName
  • Return:String
  • Summary:This property gets and sets the column name used to match with the value specified in the items.
Filters
  • Return:Collection<String>
  • Summary:N/A
IsActive
  • Return:Boolean
  • Summary:N/A
  • Return:String
  • Summary:N/A
RequiredColumnNames
  • Summary:N/A
ValueItems
  • Return:Collection<ValueItem>
  • Summary:This property gets the collection of ValueItems. Each item can have its own value to match.
FiltersCore
  • Summary:N/A
ValueStyle()
If you use this constructor, you need to set the required properties manually.
ValueStyle(String,Collection<ValueItem>)
columnName
  • Description:The columnName used to match with the value specified in the items. valueItems * Type:Collection<ValueItem> * Description:The collection of ValueItems. Each item can have its own value to match.
Go Back
CloneDeep()
  • Return Type:Style
  • Return Type:Void
features
  • Type:IEnumerable<Feature>
canvas
labelsInThisLayer
labelsInAllLayers
Go Back
  • Return Type:Void
shapes
  • Type:IEnumerable<BaseShape>
canvas
labelsInThisLayer
labelsInAllLayers
Go Back
  • Return Type:Void
canvas
drawingExtent
Go Back
DrawSample(GeoCanvas)
  • Return Type:Void
canvas
Go Back
  • Return Type:Boolean
obj
Go Back
  • Return Type:Int32
GetRequiredColumnNames()
  • Return Type:Collection<String>
  • Return Type:Type
SaveStyle(String)
  • Return Type:Void
filePathName
Go Back
SaveStyle(Stream)
  • Return Type:Void
stream
  • Type:Stream
Go Back
  • Return Type:String
CloneDeepCore()
  • Return Type:Style
  • Return Type:Void
  • Description:None
features
canvas
  • Type:GeoCanvas
labelsInThisLayer
labelsInAllLayers
Go Back
  • Return Type:Void
canvas
drawingExtent
Go Back
  • Return Type:Void
GetRequiredColumnNamesCore()
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:This method returns a collection of the column names that it needs.
  • Return Type:Object
ColumnName
This is the column we use for matching.
Return Type:String
Go Back
Filters
Go Back
IsActive
Return Type:Boolean
Go Back
Return Type:String
Go Back
RequiredColumnNames
Go Back
ValueItems
You will want to add ValueItems to this collection. Each item can have its own style and matching string.
Return Type:Collection<ValueItem>
Go Back
FiltersCore
Go Back
thinkgeo.mapsuite.core.valuestyle.1442486510.txt.gz · Last modified: 2015/09/17 10:41 by admin
