thinkgeo.mapsuite.core.tilematrix
ThinkGeo.MapSuite.Core.TileMatrix
TileMatrix(String,Double,Int32,Int32,GeographyUnit,PointShape,MatrixReferenceCorner,Int64,Int64)
If you use this constructor, all other properties are caculated via these given parameters.
  • id
    • Description:This parameter specifies the id to set the Matrix.
  • scale
    • Description:This parameter specifies the target scale to set the Matrix.
  • tileWidth
    • Description:This parameter specifies the tile width(in decimalDegrees) to set the Matrix.
  • tileHeight
    • Description:This parameter specifies the tile height(in decimalDegrees) to set the Matrix.
  • boundingBoxUnit
    • Description:This parameter specifies the boundingBox Unit to set the Matrix.
  • referencePoint
    • Description:This parameter specifies the reference point location to set the Matrix.
  • referenceCorner
    • Description:This parameter specifies the reference corner to set the Matrix.
  • rowCount
    • Type:Int64
    • Description:This parameter specifies the row count to set the Matrix.
  • columnCount
    • Type:Int64
    • Description:This parameter specifies the column count to set the Matrix.
TileMatrix(String,Double,Int32,Int32,GeographyUnit,RectangleShape,MatrixReferenceCorner)
  • id
  • scale
  • tileWidth
  • tileHeight
  • boundingBoxUnit
  • boundingBox
    • Description:This parameter specifies the boundingBox to set the Matrix.
  • referenceCorner
TileMatrix(String,Double,Int32,Int32,GeographyUnit,MatrixReferenceCorner)
  • id
  • scale
  • tileWidth
  • tileHeight
  • boundingBoxUnit
  • referenceCorner
GetAllCells()
GetCell(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetCell(PointShape)
  • intersectingPoint
GetRowIndex(PointShape)
  • Type:Int64
  • intersectingPoint
GetColumnIndex(PointShape)
  • Type:Int64
  • intersectingPoint
GetIntersectingCells(RectangleShape)
GetContainedCells(RectangleShape)
GetIntersectingRowColumnRange(RectangleShape)
GetContainedRowColumnRange(RectangleShape)
GetResolutionFromScale(Double)
This method will get resolution from scale and can be overridden.
  • Description:Returns the resolution corresponding to the passed in scale.
  • scale
    • Description:This parameter specifies the target scale to get resolution from.
SetMatrix(String,Double,Double,RectangleShape,MatrixReferenceCorner)
  • id
  • cellWidth
  • cellHeight
SetMatrix(String,Double,Double,PointShape,MatrixReferenceCorner,Int64,Int64)
  • id
  • cellWidth
  • cellHeight
  • rowCount
    • Type:Int64
  • columnCount
    • Type:Int64
SetMatrix(Double,Double)
  • cellWidth
  • cellHeight
Scale
This property gets or sets the Scale for the TileMatrix.
When set a different Scale, it will recaculate the parameters in TileMatrix.
TileWidth
This property gets or sets the TileWidth for the TileMatrix.
When set a different TileWidth, it will recaculate the parameters in TileMatrix.
TileHeight
This property gets or sets the TileHeight for the TileMatrix.
When set a different TileHeight, it will recaculate the parameters in TileMatrix.
BoundingBoxUnit
This property gets or sets the BoundingBoxUnit for the TileMatrix.
When set a different BoundingBoxUnit, it will recaculate the parameters in TileMatrix. Also, The default boundingBox value depends on the BoundingBoxUint.
CellWidth
CellHeight
BoundingBox
RowCount
  • Type:Int64
ColumnCount
  • Type:Int64
Id
thinkgeo.mapsuite.core.tilematrix.1442555592.txt.gz · Last modified: 2015/09/18 05:53 by admin
