If you use this constructor, all other properties are caculated via these given parameters.
id
tileWidth
boundingBoxUnit
referenceCorner
columnCount
scale
tileHeight
boundingBox
id
tileWidth
boundingBoxUnit
This method will get resolution from scale and can be overridden.
scale
id
cellWidth
cellHeight
boundingBox
referenceCorner
id
cellWidth
cellHeight
referencePoint
referenceCorner
rowCount
columnCount
Return Type:RectangleShape
This property gets or sets the BoundingBoxUnit for the TileMatrix.
When set a different BoundingBoxUnit, it will recaculate the parameters in TileMatrix. Also, The default boundingBox value depends on the BoundingBoxUint.
Return Type:GeographyUnit
Return Type:Double
Return Type:Double
Return Type:Int64
Return Type:String
Return Type:Int64
This property gets or sets the Scale for the TileMatrix.
When set a different Scale, it will recaculate the parameters in TileMatrix.
Return Type:Double
This property gets or sets the TileHeight for the TileMatrix.
When set a different TileHeight, it will recaculate the parameters in TileMatrix.
Return Type:Int32
This property gets or sets the TileWidth for the TileMatrix.
When set a different TileWidth, it will recaculate the parameters in TileMatrix.
Return Type:Int32
