This class represents a layer backed by SQLite.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.FeatureLayer ThinkGeo.MapSuite.Core.SqliteFeatureLayer
SqliteFeatureLayer | This is default constructor. | ||
SqliteFeatureLayer | String, String, String, String | This constructor allows you to pass in everything the layer need to load assuming that the layer itself will manage the database connections. | |
SqliteFeatureLayer | SQLiteConnection, String, String, String | This constructor allows you to pass in everything the layer need to load assuming that you will pass in a connection and we will re-use it. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
Equals | Object | Object | See Object documentation. |
ExecuteNonQuery | String | This method executes a query that does not return a SQL result. | |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetFirstGeometryType | Get The shape type from the first record. | ||
GetHashCode | Object | See Object documentation. | |
GetType | Object | See Object documentation. | |
![]() LoadLayer | Stream | Layer | Not Used in this layer. |
![]() LoadLayer | Uri | Layer | Not Used in this layer. |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | Layer | ||
RequestDrawing | RectangleShape, TimeSpan, BufferTimeType | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | TimeSpan, BufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, BufferTimeType | Layer | |
ToString | Object | See Object documentation. |
IsOpenCore | Boolean | Layer(overriden) |
| connectionString | String<!– System.String –> | |
| tableName | String<!– System.String –> | |
| featureIdColumn | String<!– System.String –> | |
| geometryColumnName | String<!– System.String –> |
| connection | SQLiteConnection<!– System.Data.SQLite.SQLiteConnection –> | |
| featureIdeColumn | String<!– System.String –> | |
| Layer<!– ThinkGeo.MapSuite.Core.Layer –> |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> |
| sqlStatement | String<!– System.String –> |
<!– ThinkGeo.MapSuite.Core.SqliteFeatureLayer –> Go Back
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| WellKnownType<!– ThinkGeo.MapSuite.Core.WellKnownType –> |
<!– static –>
<!– static –>
| bufferTimeType | BufferTimeType<!– ThinkGeo.MapSuite.Core.BufferTimeType –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
| e | Exception<!– System.Exception –> |
| e | DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.Core.DrawingFeaturesEventArgs –> |
<!– ThinkGeo.MapSuite.Core.FeatureLayer –> Go Back
| e | DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingWrappingFeaturesFeatureLayerEventArgs –> |
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
| EditTools<!– ThinkGeo.MapSuite.Core.EditTools –> |
| FeatureSource<!– ThinkGeo.MapSuite.Core.FeatureSource –> |
| Int64<!– System.Int64 –> |
| QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –> |
| WrappingMode<!– ThinkGeo.MapSuite.Core.WrappingMode –> |
| ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC SQLiteExtension ThinkGeo.MapSuite.Core UpdateDocumentation
