This class represents a layer backed by SQLite.
SqliteFeatureLayer | This is default constructor. | ||
SqliteFeatureLayer | String, String, String, String | This constructor allows you to pass in everything the layer need to load assuming that the layer itself will manage the database connections. | |
SqliteFeatureLayer | SQLiteConnection, String, String, String | This constructor allows you to pass in everything the layer need to load assuming that you will pass in a connection and we will re-use it. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
Equals | Object | Object | See Object documentation. |
ExecuteNonQuery | String | This method executes a query that does not return a SQL result. | |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetFirstGeometryType | Get The shape type from the first record. | ||
GetHashCode | Object | See Object documentation. | |
GetType | Object | See Object documentation. | |
![]() LoadLayer | Stream | Layer | Not Used in this layer. |
![]() LoadLayer | Uri | Layer | Not Used in this layer. |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | Layer | ||
RequestDrawing | RectangleShape, TimeSpan, BufferTimeType | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | TimeSpan, BufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, BufferTimeType | Layer | |
ToString | Object | See Object documentation. |
IsOpenCore | Boolean | Layer(overriden) |
| connectionString | String | |
| tableName | String | |
| featureIdColumn | String | |
| geometryColumnName | String |
| connection | SQLiteConnection | |
| featureIdeColumn | String | |
| Layer |
| Void |
| Void |
| canvas | GeoCanvas | |
| labelsInAllLayers | Collection<SimpleCandidate> |
| Boolean |
| obj | Object |
| Int32 |
| sqlStatement | String |
| RectangleShape |
| WellKnownType |
| Int32 |
| Type |
| Layer |
| layerStream | Stream |
| Layer |
| layerUri | Uri |
| Void |
| Void |
| Void |
| extentToRefresh | RectangleShape | |
| bufferTime | TimeSpan | |
| bufferTimeType | BufferTimeType |
| Void |
| Void |
| Void |
| extentsToRefresh | IEnumerable<RectangleShape> |
| Void |
| extentsToRefresh | IEnumerable<RectangleShape> | |
| Void |
| Void |
| Void |
| String |
| Layer |
| Void |
| Void |
| Void |
| Void |
| Void |
| Void |
| RectangleShape |
| Object |
| Void |
| args | DrawingAttributionLayerEventArgs |
| Void |
| e | DrawingExceptionLayerEventArgs |
| Void |
| e | DrawingFeaturesEventArgs |
| Void |
| e | DrawingProgressChangedEventArgs |
| Void |
| e | DrawingWrappingFeaturesFeatureLayerEventArgs |
| Void |
| args | DrawnAttributionLayerEventArgs |
| Void |
| e | DrawnExceptionLayerEventArgs |
| Void |
| eventArgs | RequestedDrawingLayerEventArgs |
| Void |
| eventArgs | RequestingDrawingLayerEventArgs |
| Void |
| Void |
| Void |
| String |
| Int32 |
| String |
| DrawingExceptionMode |
| Double |
| DrawingQuality |
| TimeSpan |
| String |
| Collection<String> |
| FeatureSource |
| TimeSpan |
| Int64 |
| Int64 |
| String |
| Boolean |
| Boolean |
| Boolean |
| Boolean |
| Boolean |
| Int32 |
| String |
| QueryTools |
| TimeSpan |
| TimeSpan |
| String |
| Single |
| String |
| RectangleShape |
| WrappingMode |
| ZoomLevelSet |
| Boolean |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC SQLiteExtension ThinkGeo.MapSuite.Core UpdateDocumentation
