<!– Class –> The event args containing the event data used by SecuredTiledWmsRasterSource.
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.SendingRequestWmsRasterSourceEventArgs
SendingRequestWmsRasterSourceEventArgs | |||
SendingRequestWmsRasterSourceEventArgs | WebRequest | Create an instance of SendingRequestWmsRasterSourceEventArgs |
WebRequest | WebRequest | Gets or sets the request object |
| webRequest | WebRequest<!– System.Net.WebRequest –> |
<!– ThinkGeo.MapSuite.Core.SendingRequestWmsRasterSourceEventArgs –> Go Back
