thinkgeo.mapsuite.core.qualityfamilyareastyle
ThinkGeo.MapSuite.Core.QualityFamilyAreaStyle
    • ThinkGeo.MapSuite.Core.Style
      • ThinkGeo.MapSuite.Core.AreaStyle
        • ThinkGeo.MapSuite.Core.QualityFamilyAreaStyle
QualityFamilyAreaStyle()
This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually.
QualityFamilyAreaStyle(GeoPen,GeoColor,Int32)
None.
  • outlinePen
    • Type:GeoPen
    • Description:This parameter represents the outline pen that will be used on the style.
  • baseColor
    • Type:GeoColor
    • Description:This parameter represents the base color that will be used in the class.
  • numberOfColors
    • Description:This prameter represents how many colors will be used in the style, based on the base color.
QualityFamilyAreaStyle(GeoPen,GeoColor,Int32,PenBrushDrawingOrder)
None.
  • outlinePen
    • Type:GeoPen
  • baseColor
    • Type:GeoColor
  • numberOfColors
  • penBrushDrawingOrder
    • Description:This parameter describes the PenBrushDrawingOrder that will be used when drawing the area type feature.
ClearCache()
This method clears the cached style in the cache.
  • Description:None.
CloneDeep()
  • Type:Style
  • features
    • Type:IEnumerable<Feature>
  • shapes
    • Type:IEnumerable<BaseShape>
GetRequiredColumnNames()
  • Type:Collection<String>
DrawSample(GeoCanvas)
SaveStyle(String)
  • filePathName
SaveStyle(Stream)
  • stream
    • Type:Stream
  • Description:None
  • features
  • canvas
    • Type:GeoCanvas
  • labelsInThisLayer
  • labelsInAllLayers
CloneDeepCore()
  • Type:Style
GetRequiredColumnNamesCore()
NumberOfColors
This gets or sets the number of colors in the style.
None.
Cache
This gets the cached style in the class.
This gets the cached style in the class. The key of the style in the cache is feature.Id & feature.GetHashCode().
BaseColor
This gets or sets the base color of the style.
None.
XOffsetInPixel
  • Type:Single
YOffsetInPixel
  • Type:Single
FillSolidBrush
CustomAreaStyles
OutlinePen
Advanced
DrawingLevel
IsActive
RequiredColumnNames
Filters
uBs=
FiltersCore
thinkgeo.mapsuite.core.qualityfamilyareastyle.1442555385.txt.gz · Last modified: 2015/09/18 05:49 by admin
