If you use this constructor, you should set the various properties manually. Specifically, you will want to set the PointType, which allows you to choose between bitmap, character and symbol as an option for displaying your points.
If you use this constructor, the PointStyle will be set to Bitmap.
PointStyle(GeoFont,Int32,GeoSolidBrush)
If you use this constructor, the PointStyle will be set to Character.
PointStyle(PointSymbolType,GeoSolidBrush,Int32)
If you use this constructor, the PointStyle will be set to Symbol.
PointStyle(PointSymbolType,GeoSolidBrush,GeoPen,Int32)
This method draws a sample feature on the canvas you provided.
This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area. When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
When using the PointStyle you choose between a bitmap, a font or a predefined symbol to represent the point. Each of these options has corresponding properties on the point symbol. If you set the type to character, then you need to set the properties that start with “Character,” such as “CharacterFont.” The same is true for the symbol.
This property gets and sets the image used if the PointType property is Bitmap.
This property is where you can set the image for the points if the PointType is Bitmap. It uses a GeoImage, so you can either reference a file or supply a stream.
This property allows you to scale the image up and down depending on how large or small you want it. It can be changed dynamically, so you could change it at every scale level to resize the bitmap based on the current scale. A scale of 1 would be the original size, while a scale of 2 would double the size. A scale of .5 would reduce the size of the image by half, and so on.
This property gets and sets the font that is used for the character if the PointType is Character.
This property allows you to set the font from which to select a character index if you choose the Character PointType.
This property gets and sets the index position of the character you want to use from the font you selected in the CharacterFont property.
You need to specify the index position of the character you want to use from the font you selected. For example, if you choose 1, then we will use the first character in the font you set in the CharacterFont property.
This property gets and sets the SolidBrush used to color the font character for the point.
This brush is used to draw the character. It is only used if the PointType is Character. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
This property gets and sets the type of symbol you want to use if the PointType is Symbol.
You can choose between a number of predefined symbols. The symbols are simple geometric objects that are typically used for abstract representations on a map. If there is a specific symbol you need that is not part of our symbol collection, you can submit it to us and we will consider adding it.
