This layer represents multiple Shape Files of the same type.
If you use this constructor, then you need to set to required properties manually.
This constructor allows you to pass in the path and filename pattern to match.
multipleShapeFilePattern
indexFilePattern
This is the constructor for this class. You can pass in a group of shapes and its corresponding indexs like string[] shapeFiles = new string[] { “C:\CA_counties.shp”, “C:\AZ_counties.shp” }; string[] indexFiles = new string[] { “C:\CA_counties.midx”, “C:\AZ_counties.midx” }; In this way, the MultipleShapeFileFeatureLayer will construct from the passing 2 shapes.
shapeFiles
This method builds a spatial index for the layer.
multipleShapeFiles
multipleShapeFileIndexes
buildIndexMode
This index-building method is very useful when you have a large number of Shape Files that contain only certain records you want. For example, you may have an individual Shape File for the states of Texas and Florida that contains only those states' roads. They are named TXRoads.shp for Texas and FLRoads.shp for Florida. Inside of these Shape Files there is a column that determines whether the roads are normal streets or highways. You, of course, want to draw highways differently. You could use a ValueStyle, but that would be slow because you'd have to look though all of the records at runtime to determine which are the highways. A better solution is to build a custom index that only has highways in it. In this way, you generate the index once and then runtime performance is fast. In our scenario, we would create an index to include all of the road Shape Files by using the pattern “*Roads.shp”. This will make sure we get both the Texas and Florida roads. Next, we specify the RoadType column as the column parameter. Then we provide a regular expression match that picks out all of the highways, and name the resulting index “Highways.idx”. We can then build another, separate index just for the normal streets. In this way, we can quickly sort the roads from the highways – and we didn't have to cut up our Shape Files to do it.
columnName
regularExpression
indexFilename
buildIndexMode
columnName
regularExpression
indexFilename
This overload allows you to pass in a path and filename pattern for Shapes Files and index files. If you use a pattern for the index file name, it will generate indexes for each Shape File it finds, matching the index file names to the Shape File names. Alternatively, if you use a concrete index file name, it will generate one large index instead. If you enter an indexFilePattern like “C:\Roads\??Roads.idx”, it will build individual indexes for each Shape File and name them according to the pattern. If you enter an absolute name, like “C:\Roads\Roads.idx”, it will create one large index for all of the Shape Files.
indexFilePattern
buildIndexMode
indexFilePattern
This overload allows you to pass in a Shape File path and filename pattern and determines if we re-build index files that already exist. It will generate indexes for each Shape File it finds, matching the index file names to the Shape File names.
buildIndexMode
This overload allows you to pass in a Shape File path and filename pattern. It will generate indexes for each Shape File it finds, matching the index file names to the Shape File names.
multipleShapeFiles
canvas
labelsInAllLayers
This method returns a collection of the index files and their paths that make up the layer.
This method returns a collection of the Shape Files and their paths that make up the layer.
extentToRefresh
bufferTime
bufferTimeType
extentsToRefresh
bufferTime
bufferTime
bufferTimeType
extentsToRefresh
bufferTime
bufferTimeType
canvas
featuresForFilters
labelsInAllLayers
currentZoomLevel
marginWorldExtent
canvas
labelsInAllLayers
Return Type:String
Return Type:Single
Return Type:DrawingExceptionMode
Return Type:Single
Return Type:Double
Return Type:DrawingQuality
Return Type:TimeSpan
This property gets and sets the encoding information for the DBF.
Return Type:Encoding
Return Type:Collection<String>
Return Type:FeatureSource
Return Type:GeometryValidationMode
Return Type:Single
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In MultipleShapeFeatureLayer, we override this API and mark it as true.
Return Type:Boolean
This property gets and sets the index file pattern that makes up this layer.
Return Type:String
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Int32
This property gets and sets the Shape File pattern that makes up this layer.
Return Type:String
Return Type:String
Return Type:QueryTools
Return Type:Single
Return Type:Single
Return Type:RectangleShape
Return Type:WrappingMode
Return Type:ZoomLevelSet
Return Type:Boolean
Return Type:Int64
Return Type:Int64
