<!– Class –> This class represents a layer backed by Microsoft SQL 2008.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.FeatureLayer ThinkGeo.MapSuite.Core.MsSql2008FeatureLayer
MsSql2008FeatureLayer | This is the constructor for the class. | ||
MsSql2008FeatureLayer | String, String, String | This is the constructor for the class. | |
MsSql2008FeatureLayer | String, String, String, DatabaseConnectionMode | ||
MsSql2008FeatureLayer | String, String, String, Int32 | This is the constructor for the class. | |
MsSql2008FeatureLayer | String, String, String, Int32, String | ||
MsSql2008FeatureLayer | String, String, String, Int32, DatabaseConnectionMode | ||
MsSql2008FeatureLayer | String, String, String, Int32, String, DatabaseConnectionMode |
BuildIndex | BuildIndexMode | Build Spatial index | |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
![]() CreateTable | String, String, SpatialDataType | This method creates a Sql Spatial Data table in MsSql2008 server. | |
![]() CreateTable | String, String, SpatialDataType, IEnumerable<FeatureSourceColumn> | This method creates a Sql Spatial Data table in MsSql2008 server. | |
![]() CreateTable | String, String, SpatialDataType, IEnumerable<FeatureSourceColumn>, OverwriteMode | This method creates a Sql Spatial Data table in MsSql2008 server. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
ExecuteNonQuery | String | This method executes a query that does not return a SQL result. | |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetFirstGeometryType | Get The shape type from the first record. | ||
![]() LoadLayer | Uri | Layer | |
![]() LoadLayer | Stream | Layer | |
MakeAllGeometriesValid | To make the geometry type data valid, and update the table. | ||
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
ToString | Object | ||
Validate | Check if all geometry are valid for spatial query. |
CommandTimeout | Int32 | This property gets and sets the amount of time that can elapse before the command will timeout and abort. | |
ConnectionString | String | This property gets and sets the connection string that will be used to connect to the server. | |
CustomGeometryColumnName | String | ||
DatabaseConnectionMode | DatabaseConnectionMode | ||
DrawingMarginInPixel | Single | FeatureLayer | |
DrawingQuality | DrawingQuality | FeatureLayer | This property gets and sets the general drawing quality for the FeatureLayer's canvas. |
EditTools | EditTools | FeatureLayer | This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer. |
FeatureIdColumn | String | This property gets or sets the name of the column that holds the unique feature Id. | |
FeatureIdsToExclude | Collection<String> | FeatureLayer | A collection of strings representing record id of features not to get in the Layer. |
FeatureSource | FeatureSource | FeatureLayer | This property gets the FeatureSource for the FeatureLayer. |
GeometryValidationMode | GeometryValidationMode | FeatureLayer | |
HasBoundingBox | Boolean | Layer(overriden) | This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In MsSql2008FeatureLayer, we override this API and mark it as true. |
MaxRecordsToDraw | Int32 | FeatureLayer | |
QueryTools | QueryTools | FeatureLayer | This property gets the QueryTools that allow you to easily query Features from the Feature Layer. |
SchemaName | String | ||
SpatialIndexName | String | ||
Srid | Int32 | Specify what kind srid data to be used. | |
TableName | String | This property gets or sets the table name that the database will use. | |
WhereClause | String | ||
WrappingExtent | RectangleShape | FeatureLayer | |
WrappingMode | WrappingMode | FeatureLayer | Thie property gets or sets whether allow wrap date line. |
ZoomLevelSet | ZoomLevelSet | FeatureLayer | This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer. |
IsOpenCore | Boolean | Layer(overriden) |
DrawingAttribution | DrawingAttributionLayerEventArgs | Layer | |
DrawingException | DrawingExceptionLayerEventArgs | Layer | |
DrawingFeatures | DrawingFeaturesEventArgs | FeatureLayer | This event is raised when features are about to be drawn in the layer. |
DrawingProgressChanged | DrawingProgressChangedEventArgs | Layer | |
DrawingWrappingFeatures | DrawingWrappingFeaturesFeatureLayerEventArgs | FeatureLayer | |
DrawnAttribution | DrawnAttributionLayerEventArgs | Layer | |
DrawnException | DrawnExceptionLayerEventArgs | Layer | |
RequestedDrawing | RequestedDrawingLayerEventArgs | Layer | |
RequestingDrawing | RequestingDrawingLayerEventArgs | Layer |
This is the default constructor, but it is not typically used.
This constructor allows you to pass in all of the data to create the Layer.
| connectionString | String<!– System.String –> | This parameter represents the connection string that will be used to connect to the server. |
| tableName | String<!– System.String –> | This parameter represents the table name being accessed. |
| featureIdColumn | String<!– System.String –> | This parameter represents the name of the column that holds the unique feature Id. |
| connectionString | String<!– System.String –> | |
| tableName | String<!– System.String –> | |
| featureIdColumn | String<!– System.String –> | |
| databaseConnectionMode | DatabaseConnectionMode<!– ThinkGeo.MapSuite.Core.DatabaseConnectionMode –> |
| srid | Int32<!– System.Int32 –> | Specify what kind srid data to be used. |
| srid | Int32<!– System.Int32 –> | |
| schemaName | String<!– System.String –> |
| schemaName | String<!– System.String –> | |
Build Spatial index
| buildIndexMode | BuildIndexMode<!– ThinkGeo.MapSuite.Core.BuildIndexMode –> | Build Index Mode |
<!– ThinkGeo.MapSuite.Core.MsSql2008FeatureLayer –> Go Back
<!– static –> This method creates a Sql Spatial Data table in MsSql2008 server.
| connectionString | String<!– System.String –> | Represents the connection string to the database |
| tableName | String<!– System.String –> | Represents the name for the table |
| spatialDataType | SpatialDataType<!– ThinkGeo.MapSuite.Core.SpatialDataType –> | Represents the Spatial Data Type for the Spatial Data column |
| columns | IEnumerable<FeatureSourceColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.FeatureSourceColumn} –> | Represnts information for creating columns besides Spatial Data Column |
| overwriteMode | OverwriteMode<!– ThinkGeo.MapSuite.Core.OverwriteMode –> | Indicates whether need to overwrite the datatable if there's already an exsited one |
This methods executes a query that has no results.
| sqlStatement | String<!– System.String –> | This parameter represents the SQL statement that will be executed. |
| WellKnownType<!– ThinkGeo.MapSuite.Core.WellKnownType –> | The shape type of the first record. |
<!– static –>
<!– static –>
This function will check whether the geometry is valid for spatial query, if it is not, then the function will make it valid and save it back to the table. For example: Here's a invalid LineString LINESTRING(0 2,1 1,1 0,1 1,2 2)) which is overlaps itself, it's invalid. After use this function, it will be MULTILINESTRING1)
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> | If all geometry are valid, the count of the returning dictionary is 0. |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
This method raises the DrawingFeatures event.
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
| e | DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.Core.DrawingFeaturesEventArgs –> | This parameter represents the event arguments for the event. |
<!– ThinkGeo.MapSuite.Core.FeatureLayer –> Go Back
| e | DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingWrappingFeaturesFeatureLayerEventArgs –> |
This method sets up the EditTools and QueryTools objects.
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
You can use this to set a time limit for the query before it times out.
The DrawingQuality enumeration allows you to control, in a macro sense, the drawing quality that will be used in the GeoCanvas. Each GeoCanvas, which is responsible for drawing of the features, may have its own specialized drawing quality properties. What the DrawingQuality enumeration does is define some general guidelines for each GeoCanvas. For example, if you set the DrawingQuality to HighSpeed, then inside of the GdiPlusGeoCanvas there is a profile for HighSpeed. This profile sets specific properties, such as the smoothing mode and composing drawing mode of the GdiPlusGeoCanvas. As each GeoCanvas may have different drawing quality properties, this offers a general way to control drawing quality and speed.
If you need complete control over how a specific GeoCanvas will draw, then you can set the DrawingQuality to Custom. This will tell the specific GeoCanvas to use the properties on its own object instead of one of the pre-defined profiles. If one of the profiles – such as HighSpeed or HighQuality – is set, then the specific GeoCanvas ignores its own properties for drawing quality.
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
| EditTools<!– ThinkGeo.MapSuite.Core.EditTools –> |
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
| FeatureSource<!– ThinkGeo.MapSuite.Core.FeatureSource –> |
| GeometryValidationMode<!– ThinkGeo.MapSuite.Core.GeometryValidationMode –> |
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
| QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –> |
| WrappingMode<!– ThinkGeo.MapSuite.Core.WrappingMode –> |
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
| ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
| Event Arguments |
| Event Arguments |
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
