thinkgeo.mapsuite.core.mapsuitetilematrix
ThinkGeo.MapSuite.Core.MapSuiteTileMatrix
This class defines the TileMatrix system used in MapSuite component.
    • ThinkGeo.MapSuite.Core.Matrix
      • ThinkGeo.MapSuite.Core.TileMatrix
        • ThinkGeo.MapSuite.Core.MapSuiteTileMatrix
MapSuiteTileMatrix
  • Parameters:Double
  • DeclaringType:N/A
  • Summary:This is the constructor by passing the scale.
MapSuiteTileMatrix
  • Parameters:Double,Int32,Int32,GeographyUnit
  • DeclaringType:N/A
  • Summary:This is the constructor for the class.
MapSuiteTileMatrix
MapSuiteTileMatrix
  • Parameters:Double,Int32,Int32,GeographyUnit,PointShape,Int64,Int64
  • DeclaringType:N/A
MapSuiteTileMatrix
MapSuiteTileMatrix
  • Parameters:String,Double,Int32,Int32,GeographyUnit,PointShape,Int64,Int64
  • DeclaringType:N/A
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetAllCells
  • Parameters:N/A
  • DeclaringType:Matrix
  • Summary:N/A
GetCell
  • Parameters:Int64,Int64
  • Summary:N/A
GetCell
GetColumnIndex
GetContainedCells
GetContainedRowColumnRange
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetIntersectingCells
GetIntersectingRowColumnRange
GetRowIndex
GetType
  • Parameters:N/A
  • Summary:N/A
ToString
  • Parameters:N/A
  • Summary:N/A
Finalize
  • Parameters:N/A
  • Summary:N/A
GetResolutionFromScale
  • Parameters:Double
  • DeclaringType:N/A
  • Summary:This method will get resolution from scale and can be overridden.
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
SetMatrix
SetMatrix
SetMatrix
  • Parameters:Double,Double
  • Summary:N/A
BoundingBox
BoundingBoxUnit
CellHeight
  • Return:Double
  • Summary:N/A
CellWidth
  • Return:Double
  • Summary:N/A
ColumnCount
  • Return:Int64
  • Summary:N/A
Id
  • Return:String
  • Summary:N/A
RowCount
  • Return:Int64
  • Summary:N/A
Scale
  • Return:Double
  • Summary:N/A
TileHeight
  • Return:Int32
  • Summary:N/A
TileWidth
  • Return:Int32
  • Summary:N/A
MapSuiteTileMatrix(Double)
If you use this constructor, all other properties are used their default values.
scale
  • Description:This parameter specifies the target scale to set the Matrix. Go Back === MapSuiteTileMatrix(Double,Int32,Int32,GeographyUnit) === This is the constructor for the class. ==== Remarks ==== If you use this constructor, all other properties are used their default values. ==== Parameters ==== scale * Type:Double * Description:This parameter specifies the target scale to set the Matrix.
tileWidth
  • Description:This parameter specifies the tile width(in decimalDegrees) to set the Matrix. tileHeight * Type:Int32 * Description:This parameter specifies the tile height(in decimalDegrees) to set the Matrix.
boundingBoxUnit
  • Description:This parameter specifies the boundingBox Unit to set the Matrix. Go Back === MapSuiteTileMatrix(Double,Int32,Int32,GeographyUnit,RectangleShape) === This is the constructor for the class. ==== Remarks ==== If you use this constructor, all other properties are used their default values. ==== Parameters ==== scale * Type:Double * Description:This parameter specifies the target scale to set the Matrix.
tileWidth
boundingBoxUnit
  • Description:This parameter specifies the boundingBox Unit to set the Matrix. boundingBox * Type:RectangleShape * Description:This parameter specifies the bounding box to set the Matrix.
Go Back
MapSuiteTileMatrix(Double,Int32,Int32,GeographyUnit,PointShape,Int64,Int64)
scale
  • Description:This parameter specifies the target scale to set the Matrix. tileWidth * Type:Int32 * Description:This parameter specifies the tile width(in decimalDegrees) to set the Matrix.
tileHeight
  • Description:This parameter specifies the tile height(in decimalDegrees) to set the Matrix. boundingBoxUnit * Type:GeographyUnit * Description:This parameter specifies the boundingBox Unit to set the Matrix.
referencePoint
  • Description:This parameter specifies the reference point location to set the Matrix. rowCount * Type:Int64 * Description:This parameter specifies the row count to set the Matrix.
columnCount
  • Type:Int64
  • Description:This parameter specifies the column count to set the Matrix. Go Back === MapSuiteTileMatrix(String,Double,Int32,Int32,GeographyUnit,RectangleShape) === This is the constructor for the class. ==== Remarks ==== If you use this constructor, all other properties are used their default values. ==== Parameters ==== id * Type:String * Description:This parameter specifies the id to set the Matrix.
scale
tileHeight
boundingBox
  • Description:This parameter specifies the bounding box to set the Matrix. Go Back === MapSuiteTileMatrix(String,Double,Int32,Int32,GeographyUnit,PointShape,Int64,Int64) === This is the constructor for the class. ==== Remarks ==== If you use this constructor, all other properties are used their default values. ==== Parameters ==== id * Type:String * Description:This parameter specifies the id to set the Matrix.
scale
tileHeight
referencePoint
columnCount
  • Type:Int64
  • Description:This parameter specifies the column count to set the Matrix. Go Back ===== Protected Constructors ===== ===== Public Methods ===== === Equals(Object) === N/A ==== Remarks ==== N/A Return Value * Return Type:Boolean * Description:N/A ==== Parameters ==== obj * Type:Object * Description:N/A Go Back === GetAllCells() === N/A ==== Remarks ==== N/A Return Value * Return Type:Collection<TileMatrixCell> * Description:N/A ==== Parameters ==== Go Back === GetCell(Int64,Int64) === N/A ==== Remarks ==== N/A Return Value * Return Type:TileMatrixCell * Description:N/A ==== Parameters ==== row * Type:Int64 * Description:N/A column * Type:Int64 * Description:N/A Go Back === GetCell(PointShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:TileMatrixCell * Description:N/A ==== Parameters ==== intersectingPoint * Type:PointShape * Description:N/A Go Back === GetColumnIndex(PointShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:Int64 * Description:N/A ==== Parameters ==== intersectingPoint * Type:PointShape * Description:N/A Go Back === GetContainedCells(RectangleShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:Collection<TileMatrixCell> * Description:N/A ==== Parameters ==== worldExtent * Type:RectangleShape * Description:N/A Go Back === GetContainedRowColumnRange(RectangleShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:RowColumnRange * Description:N/A ==== Parameters ==== worldExtent * Type:RectangleShape * Description:N/A Go Back === GetHashCode() === N/A ==== Remarks ==== N/A Return Value * Return Type:Int32 * Description:N/A ==== Parameters ==== Go Back === GetIntersectingCells(RectangleShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:Collection<TileMatrixCell> * Description:N/A ==== Parameters ==== worldExtent * Type:RectangleShape * Description:N/A Go Back === GetIntersectingRowColumnRange(RectangleShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:RowColumnRange * Description:N/A ==== Parameters ==== worldExtent * Type:RectangleShape * Description:N/A Go Back === GetRowIndex(PointShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:Int64 * Description:N/A ==== Parameters ==== intersectingPoint * Type:PointShape * Description:N/A Go Back === GetType() === N/A ==== Remarks ==== N/A Return Value * Return Type:Type * Description:N/A ==== Parameters ==== Go Back === ToString() === N/A ==== Remarks ==== N/A Return Value * Return Type:String * Description:N/A ==== Parameters ==== Go Back ===== Protected Methods ===== === Finalize() === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== Go Back === GetResolutionFromScale(Double) === This method will get resolution from scale and can be overridden. ==== Remarks ==== N/A Return Value * Return Type:Double * Description:Returns the resolution corresponding to the passed in scale. ==== Parameters ==== scale * Type:Double * Description:This parameter specifies the target scale to get resolution from. Go Back === MemberwiseClone() === N/A ==== Remarks ==== N/A Return Value * Return Type:Object * Description:N/A ==== Parameters ==== Go Back === SetMatrix(String,Double,Double,RectangleShape,MatrixReferenceCorner) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== id * Type:String * Description:N/A cellWidth * Type:Double * Description:N/A cellHeight * Type:Double * Description:N/A boundingBox * Type:RectangleShape * Description:N/A referenceCorner * Type:MatrixReferenceCorner * Description:N/A Go Back === SetMatrix(String,Double,Double,PointShape,MatrixReferenceCorner,Int64,Int64) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== id * Type:String * Description:N/A cellWidth * Type:Double * Description:N/A cellHeight * Type:Double * Description:N/A referencePoint * Type:PointShape * Description:N/A referenceCorner * Type:MatrixReferenceCorner * Description:N/A rowCount * Type:Int64 * Description:N/A columnCount * Type:Int64 * Description:N/A Go Back === SetMatrix(Double,Double) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== cellWidth * Type:Double * Description:N/A cellHeight * Type:Double * Description:N/A Go Back ===== Public Properties ===== === BoundingBox === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:RectangleShape Go Back === BoundingBoxUnit === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:GeographyUnit Go Back === CellHeight === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Double Go Back === CellWidth === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Double Go Back === ColumnCount === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Int64 Go Back === Id === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:String Go Back === RowCount === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Int64 Go Back === Scale === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Double Go Back === TileHeight === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Int32 Go Back === TileWidth === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type**:Int32
Go Back
thinkgeo.mapsuite.core.mapsuitetilematrix.1442486097.txt.gz · Last modified: 2015/09/17 10:34 by admin
