<!– Class –> This class defines the TileMatrix system used in MapSuite component.
This MapSuite Tile Matrix system is the TileMatrix system designed for use both in Desktop Edition and Web Edition.
*System.Object ThinkGeo.MapSuite.Core.Matrix *ThinkGeo.MapSuite.Core.TileMatrix ThinkGeo.MapSuite.Core.MapSuiteTileMatrix
![]() | Double | This is the constructor by passing the scale. | |
![]() | Double, Int32, Int32, GeographyUnit | This is the constructor for the class. | |
![]() | Double, Int32, Int32, GeographyUnit, RectangleShape | This is the constructor for the class. | |
![]() | Double, Int32, Int32, GeographyUnit, PointShape, Int64, Int64 | This is the constructor for the class. | |
![]() | String, Double, Int32, Int32, GeographyUnit, RectangleShape | This is the constructor for the class. | |
![]() | String, Double, Int32, Int32, GeographyUnit, PointShape, Int64, Int64 | This is the constructor for the class. |
![]() | Object | Object | |
![]() | Matrix | This method returns all the cells of the TileMatrix. | |
![]() | Int64, Int64 | Matrix | Get the cell by passing a specified row and column. |
![]() | PointShape | Matrix | Get the cell by passing a specified point shape location. |
![]() | PointShape | Matrix | Get the column index by passing a specified point shape location. |
![]() | RectangleShape | Matrix | This method returns the contained cells of the TileMatrix. |
![]() | RectangleShape | Matrix | This method returns the RowColumnRange of the TileMatrix contained the passed in extent. |
![]() | Object | ||
![]() | RectangleShape | Matrix | This method returns the intersecting cells of the TileMatrix. |
![]() | RectangleShape | Matrix | This method returns the RowColumnRange of the TileMatrix intersects the passed in extent. |
![]() | PointShape | Matrix | Get the row index by passing a specified point shape location. |
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Double | TileMatrix(overriden) | This method will get resolution from scale and can be overridden. |
![]() | Object | ||
![]() | Double, Double | Matrix | This method sets the Matrix system by passing the cellWidth and cellHeight. |
![]() | String, Double, Double, RectangleShape, MatrixReferenceCorner | Matrix | This method sets the Matrix system by passing in each variables. |
![]() | String, Double, Double, PointShape, MatrixReferenceCorner, Int64, Int64 | Matrix | This method sets the Matrix system by passing in each variables. |
![]() | RectangleShape | Matrix | This property gets or sets the BouningBox of the Matrix. |
![]() | GeographyUnit | TileMatrix | This property gets or sets the BoundingBoxUnit for the TileMatrix. |
![]() | Double | Matrix | This property gets the cell height of the Matrix. |
![]() | Double | Matrix | This property gets the cell width of the Matrix. |
![]() | Int64 | Matrix | This property gets the column count of the Matrix. |
![]() | String | Matrix | This property gets or sets the id of the Matrix. |
![]() | Int64 | Matrix | This property gets the row count of the Matrix. |
![]() | Double | TileMatrix | This property gets or sets the Scale for the TileMatrix. |
![]() | Int32 | TileMatrix | This property gets or sets the TileHeight for the TileMatrix. |
![]() | Int32 | TileMatrix | This property gets or sets the TileWidth for the TileMatrix. |
If you use this constructor, all other properties are used their default values.
Name | Type | Description |
scale | Double<!– System.Double –> | This parameter specifies the target scale to set the Matrix. |
This is the commonly used constructor for the class.
tileWidth | Int32<!– System.Int32 –> | This parameter specifies the tile width(in decimalDegrees) to set the Matrix. |
tileHeight | Int32<!– System.Int32 –> | This parameter specifies the tile height(in decimalDegrees) to set the Matrix. |
boundingBoxUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | This parameter specifies the boundingBox Unit to set the Matrix. |
boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter specifies the bounding box to set the Matrix. |
referencePoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifies the reference point location to set the Matrix. |
rowCount | Int64<!– System.Int64 –> | This parameter specifies the row count to set the Matrix. |
columnCount | Int64<!– System.Int64 –> | This parameter specifies the column count to set the Matrix. |
id | String<!– System.String –> | This parameter specifies the id to set the Matrix. |
Return Type | Description |
Collection<TileMatrixCell><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.TileMatrixCell} –> | This method returns a collection of TileMatrixCell. |
<!– ThinkGeo.MapSuite.Core.Matrix –> Go Back
TileMatrixCell<!– ThinkGeo.MapSuite.Core.TileMatrixCell –> | The returning cell by specified the row and column. |
row | Int64<!– System.Int64 –> | This parameter specifies the row based on 1. |
column | Int64<!– System.Int64 –> | This parameter specifies the row based on 1. |
TileMatrixCell<!– ThinkGeo.MapSuite.Core.TileMatrixCell –> | The returning cell by specifing the target point location. |
intersectingPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | The parameter specified the target point location. |
Int64<!– System.Int64 –> | The returning column index by specifing the target point location. |
Collection<TileMatrixCell><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.TileMatrixCell} –> | This method returns a collection of TileMatrixCell which contained in the passed in extent. |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter specifies extent which is used to get the tiles back from. |
RowColumnRange<!– ThinkGeo.MapSuite.Core.RowColumnRange –> | This method returns the RowColumnRange contained the passed in extent. |
Collection<TileMatrixCell><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.TileMatrixCell} –> | This method returns a collection of TileMatrixCell which intersecting with the passed in extent. |
RowColumnRange<!– ThinkGeo.MapSuite.Core.RowColumnRange –> | This method returns the RowColumnRange intersects the passed in extent. |
Int64<!– System.Int64 –> | The returning row index by specifing the target point location. |
Type<!– System.Type –> |
Void<!– System.Void –> |
Double<!– System.Double –> | Returns the resolution corresponding to the passed in scale. |
scale | Double<!– System.Double –> | This parameter specifies the target scale to get resolution from. |
<!– ThinkGeo.MapSuite.Core.TileMatrix(overriden) –> Go Back
cellWidth | Double<!– System.Double –> | This parameter specifies the cell width(in decimalDegrees) to set the Matrix. |
cellHeight | Double<!– System.Double –> | This parameter specifies the cell height(in decimalDegrees) to set the Matrix. |
Accroding to the these given parameters, the referencePoint, rowCount, columnCount can be caculated.
boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter specifies the boundingBox to set the Matrix. |
referenceCorner | MatrixReferenceCorner<!– ThinkGeo.MapSuite.Core.MatrixReferenceCorner –> | This parameter specifies the reference corner to set the Matrix. |
referencePoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifies the reference Point to set the Matrix. |
The bounding box of the Matrix is related with the referencePoint, cellWidth, cellHeight and the rowCount and columnCount.
Return Type |
When set a different BoundingBoxUnit, it will recaculate the parameters in TileMatrix. Also, The default boundingBox value depends on the BoundingBoxUint.
Return Type |
<!– ThinkGeo.MapSuite.Core.TileMatrix –> Go Back
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
When set a different Scale, it will recaculate the parameters in TileMatrix.
Return Type |
When set a different TileHeight, it will recaculate the parameters in TileMatrix.
Return Type |
When set a different TileWidth, it will recaculate the parameters in TileMatrix.
Return Type |
