<!– Class –> This projection class uses the Proj4 engine to project data from one Srid to another.
This projection class uses the Proj4 engine to project data from one Srid to another. Proj4 is a very popular projection library the support thousands for projections. It uses a special text format to feed in parameters about the to and from projection. Though it uses its own format many organizations have recognized it and provide their projection definition in this format. Within this class we support the latest EPSG (European Petroleum Survey Group) SRID (Spatial Reference System Identifiers) list. You can find more information about these on the web. The SRID list is very popular and we include a text version with in our install.
Note that one thing that confuses people is that when they go to or from latitude and longitude they do not know what SRID to use. The proper SRID is 4326 for WGS84 pair coordinates in degrees with Greenwich as the central meridian.
![]() | This is the default constructor for this class. | ||
![]() | String, String | This is a constructor for the class. | |
![]() | Int32, Int32 | ||
![]() | String, Int32 | ||
![]() | Int32, String |
![]() | Projection | Create a copy of Projection using the deep clone process. | |
![]() | Projection | This method closes the projection and gets it ready for serialization if necessary. | |
![]() ![]() | Int32 | This method is a static API to get a Prj string by Epsg number | |
![]() ![]() | String | ||
![]() | Feature | Projection | This method returns a projected Feature based on the Feature passed in. |
![]() | BaseShape | Projection | This method returns a projected BaseShape based on the baseShape passed in. |
![]() | Double, Double | Projection | This method returns a projected vertex based on the coordinates passed in. |
![]() | GeoImage, RectangleShape | Projection | |
![]() | RectangleShape | Projection | This method returns a projected rectangle based on the rectangle passed in. |
![]() | GeoImage, RectangleShape, RectangleShape | Projection | |
![]() | IEnumerable<Vertex> | Projection | This method returns projected vertices based on the coordinates passed in. |
![]() | BaseShape | Projection | This method returns a de-projected BaseShape based on the BaseShape passed in. |
![]() | Feature | Projection | This method returns a de-projected Feature based on the Feature passed in. |
![]() | IEnumerable<Vertex> | Projection | This method returns de-projected vertices based on the coordinates passed in. |
![]() | RectangleShape | Projection | This method returns a de-projected rectangle based on the rectangle passed in. |
![]() | Double, Double | Projection | This method returns a de-projected vertex based on the coordinates passed in. |
![]() | Object | Object | |
![]() ![]() | This method is a static API to get a projection used by BingMaps. | ||
![]() ![]() | Int32 | This method is a static API to get a projection text from EPSG(European Petroleum Survey Group). | |
![]() ![]() | Int32 | This method is a static API to get a projection text from ERSI. | |
![]() | Projection | ||
![]() ![]() | This method is a static API to get a projection used by GoogleMap. | ||
![]() | Object | ||
![]() ![]() | BaseShape, String | ||
![]() ![]() | Feature, Int32 | ||
![]() ![]() | Feature, String | ||
![]() ![]() | Double, Double | ||
![]() ![]() | BaseShape, Int32 | ||
![]() ![]() | This method is a static API to get a projection of SphericalMercator. | ||
![]() | Object | ||
![]() ![]() | This method is a static API to get a projection text from WGS84. | ||
![]() | Projection | This method opens the projection and gets it ready to use. | |
![]() | Object |
![]() | Projection | Create a copy of GeoCanvas using the deep clone process. The default implementation uses serialization. | |
![]() | Projection(overriden) | This method closes the projection and gets it ready to serialization if necessary. | |
![]() | GeoImage, RectangleShape, RectangleShape | Projection(overriden) | |
![]() | GeoImage, RectangleShape | Projection(overriden) | |
![]() | Double[], Double[] | Projection(overriden) | This method returns a projected vertex based on the coordinates passed in. |
![]() | Double[], Double[] | Projection(overriden) | This method returns a de-projected vertex based on the coordinates passed in. |
![]() | Object | ||
![]() | Projection(overriden) | ||
![]() | Object | ||
![]() | Projection(overriden) | This method open the projection and gets it ready to use. |
![]() | Boolean | Projection | |
![]() | RectangleShape | This property specifies the Boundary for decimaldegree values. | |
![]() | String | Gets or sets the Proj4 text parameter for the to projection. This parameter typically look like “+proj=utm +zone=33 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs”. | |
![]() | String | Gets or sets the Proj4 text parameter for the from projection. This parameter typically look like “+Proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs”. | |
![]() | Boolean | Projection | This property gets the state of the projection (whether it is opened or closed). |
![]() | Boolean | Projection(overriden) | This property indicates whether this projection should be used. |
This conctructor pass nothing. After this cconstructor , you should set the InternalProjectionParametersString property and ExternalProjectionParametersString property before open to use.
Name | Type | Description |
This constructor allows you to pass in Proj4 text parameters for the to and from projection. The parameters typically look like “+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs”
This constructor allows you to pass in Proj4 text parameters for the to and from projection. The parameters typically look like “+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs” You should use this constructor when you know the parameters. If you know the SRID directly you can use the other constructor that takes the SRID.
internalProjectionParameters | String<!– System.String –> | |
externalProjectionParameters | String<!– System.String –> |
internalEpsgSrid | Int32<!– System.Int32 –> | |
externalEpsgSrid | Int32<!– System.Int32 –> |
Return Type | Description |
Projection<!– ThinkGeo.MapSuite.Core.Projection –> | A cloned Projection. |
<!– ThinkGeo.MapSuite.Core.Projection –> Go Back
Void<!– System.Void –> |
<!– static –> This method is a static API to get a Prj string by Epsg number
srid | Int32<!– System.Int32 –> | Epsg number that reprents this projection |
<!– ThinkGeo.MapSuite.Core.ManagedProj4Projection –> Go Back
<!– static –>
prjString | String<!– System.String –> |
<!– static –>
proj4String | String<!– System.String –> |
Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This method returns a projected Feature for the passed-in Feature. |
feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter is the Feature that contains a BaseShape in decimalDegreesValue to be projected. |
This method returns a projected baseShape based on the BaseShape passed in.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This method returns a projected baseShape for the passed-in BaseShape. |
baseShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This parameter is the baseShape (in decimalDegreesValue) to be projected. |
Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This method returns a projected vertex based on the coordinates passed in. |
x | Double<!– System.Double –> | This parameter is the X decimalDegreesValue of the point that will be projected. |
y | Double<!– System.Double –> | This parameter is the Y decimalDegreesValue of the point that will be projected. |
RasterProjectionResult<!– ThinkGeo.MapSuite.Core.RasterProjectionResult –> |
image | GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> | |
imageExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns a projected rectangle based on the rectangle passed in. |
rectangleShape | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter represents the rectangle you want to project. |
imageExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
targetExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
This method returns a projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically, you can call the projection utility library that has interfaces for dozens of different types of projections.
Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.managedproj4projection –> | This method returns projected vertices based on the coordinates passed in. |
vertices | IEnumerable<Vertex><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Vertex} –> | This parameter is the vertices that will be projected. |
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This method returns a de-projected BaseShape for the passed in BaseShape. |
baseShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This parameter is the baseShape (in decimalDegreesValue) to be de-projected. |
Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This method returns a de-projected Feature for the passed-in Feature. |
feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter is the Feature that contains a BaseShape in decimalDegreesValue to be de-projected. |
This method returns a de-projected vertex based on the coordinates passed in. The de-projection is important because, inside of the FeatureSource, you will in many cases go to and from various projections.
Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.managedproj4projection –> | This method returns de-projected vertices based on the coordinates passed in. |
vertices | IEnumerable<Vertex><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Vertex} –> | This parameter is the vertices that will be de-projected. |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns a de-projected rectangle based on the rectangle passed in. |
rectangleShape | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter represents the rectangle you want to de-project. |
Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This method returns a de-projected vertex based on the coordinates passed in. |
x | Double<!– System.Double –> | This parameter is the X decimalDegreesValue of the point that will be de-projected. |
y | Double<!– System.Double –> | This parameter is the Y decimalDegreesValue of the point that will be de-projected. |
<!– static –> This method is a static API to get a projection used by BingMaps.
String<!– System.String –> | A text for a projection used by BingMaps , it should like this “+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs” |
<!– static –>
<!– static –> This method is a static API to get a projection text from EPSG(European Petroleum Survey Group).
More information about it can reference to EPSG.rtf in the documentation.
String<!– System.String –> | The project text corresponding to the srid. |
srid | Int32<!– System.Int32 –> | The target Srid infromation to get the projection text from. |
<!– static –> This method is a static API to get a projection text from ERSI.
More information about it can reference to ERSI.rtf in the documentation.
GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> |
<!– static –>
<!– static –>
<!– static –> This method is a static API to get a projection used by GoogleMap.
String<!– System.String –> | A text for a projection used by GoogleMap , it should like this “+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs” |
<!– static –>
<!– static –>
shape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | |
proj4ProjectionParameters | String<!– System.String –> |
<!– static –>
feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | |
<!– static –>
<!– static –>
latitude | Double<!– System.Double –> | |
longitude | Double<!– System.Double –> |
<!– static –>
<!– static –>
<!– static –>
<!– static –>
<!– static –>
longitude | Double<!– System.Double –> | |
<!– static –>
<!– static –> This method is a static API to get a projection of SphericalMercator.
String<!– System.String –> | A text for a SphericalMercator projection, it should like this “+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs” |
Type<!– System.Type –> |
<!– static –> This method is a static API to get a projection text from WGS84.
Projection<!– ThinkGeo.MapSuite.Core.Projection –> | A cloned GeoCanvas. |
As this is the core version of the Close method it is intended to be overridden in inherited version of the class. When overriding you will be responsible freeing any state you have maintained and getting the class ready to serialization if necessary. Note that the object may be opened again so you want to make sure you can open and close the object multiple tiles without any ill effects.
In this override we call the Proj4 methods get release the handles and memory.
<!– ThinkGeo.MapSuite.Core.Projection(overriden) –> Go Back
This method returns a projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically you can call the projection utility library that has interfaces for dozens of different types of projections.
Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.managedproj4projection –> | This method returns a projected vertices based on the coordinates passed in. |
x | Double[]<!– System.Doublethinkgeo.mapsuite.core.managedproj4projection –> | This parameter is the X values of the points that will be projected. |
y | Double[]<!– System.Doublethinkgeo.mapsuite.core.managedproj4projection –> | This parameter is the Y values of the points that will be projected. |
This method returns a de-projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically you can call the projection utility library that has interfaces for dozens of different types of projections. The de-projection is important because inside of the FeatureSource you will in many cases to to and from various projections.
Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.managedproj4projection –> | This method returns a de-projected vertices based on the coordinates passed in. |
x | Double[]<!– System.Doublethinkgeo.mapsuite.core.managedproj4projection –> | This parameter is the X values of the points that will be de-projected. |
y | Double[]<!– System.Doublethinkgeo.mapsuite.core.managedproj4projection –> | This parameter is the Y values of the points that will be de-projected. |
As this is the core version of the Open method it is intended to be overridden in inherited version of the class. When overriding you will be responsible for getting the projection classes state ready for doing projections.
In this override we call the Proj4 methods get it ready for projection.
Return Type |
The default boundary is(-179.9, 89.9, 179.9, -89.9). That means when I want to project a PointShape(-179,91,89.91) out, in fact what it projects is (-179.9,89.9) because of its out of boundary.
Return Type |
Return Type |
Return Type |
This method will reflect whether the projection is opened or closed. It is set in the concrete methods Open and Close, so if you inherit from this class and override OpenCore or CloseCore, you will not need to be concerned with setting this property.
Return Type |
Return Type |
