thinkgeo.mapsuite.core.layerdefinition
ThinkGeo.MapSuite.Core.LayerDefinition
    • ThinkGeo.MapSuite.Core.LayerDefinition
LayerDefinition()
LayerDefinition(String,RectangleShape,GeographyUnit,Int32,String)
  • layerName
  • featureDensity
  • uri
LayerDefinition(String,RectangleShape,GeographyUnit,Int32,String,Style,String,String)
  • layerName
  • featureDensity
  • uri
  • style
    • Type:Style
  • name
  • description
Read(XmlNode)
  • xmlNode
    • Type:XmlNode
Columns
  • Type:Collection<String>
StyleDefinitions
LayerName
BoundingBox
DisplayExtent
GeographyUnit
FeatureDensity
Uri
Description
Projection
RecordCount
ShapeType
FileSize
  • Type:Int64
CanGeocoder
HierarchyName
IsBaseLayer
thinkgeo.mapsuite.core.layerdefinition.txt · Last modified: 2017/03/16 21:59 (external edit)
