<!– Class –>
*System.Object **ThinkGeo.MapSuite.Core.JeffersonianTools
JeffersonianTools |
CanFindAliquotPart | Feature, GeographyUnit | ||
CanSplit | Feature, GeographyUnit | ||
FindAliquotPart | Feature, String, GeographyUnit, Int32, JeffersonianSplitMode | ||
FindAliquotPart | Feature, Int32, String, GeographyUnit, Int32, JeffersonianSplitMode | ||
GetSectionNumber | Feature, GeographyUnit | ||
Split | Feature, Int32, GeographyUnit, Int32, JeffersonianSplitMode, Boolean | ||
SplitIntoQuaters | Feature, GeographyUnit, Int32 | ||
SplitNorthSouth | Feature, GeographyUnit, Int32 | ||
SplitWestEast | Feature, GeographyUnit, Int32 | ||
CanFindAliquotPartCore | Feature, GeographyUnit | ||
CanSplitCore | Feature, GeographyUnit | ||
FindAliquotPartCore | Feature, Int32, String, GeographyUnit, Int32, JeffersonianSplitMode | ||
MemberwiseClone | Object | ||
SplitCore | Feature, Int32, GeographyUnit, Int32, JeffersonianSplitMode, Boolean | ||
SplitIntoQuatersCore | Feature, GeographyUnit, Int32 | ||
SplitNorthSouthCore | Feature, GeographyUnit, Int32 | ||
SplitWestEastCore | Feature, GeographyUnit, Int32 |
| aliquotPart | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | |
| unit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> |
<!– ThinkGeo.MapSuite.Core.JeffersonianTools –> Go Back
| section | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | |
| jeffersonianString | String<!– System.String –> | |
| unit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | |
| cornerPointTolerancePercentage | Int32<!– System.Int32 –> | |
| splitMode | JeffersonianSplitMode<!– ThinkGeo.MapSuite.Core.JeffersonianSplitMode –> |
| sectionNumber | Int32<!– System.Int32 –> | |
| JeffersonianSplitResult<!– ThinkGeo.MapSuite.Core.JeffersonianSplitResult –> | The result represent by the JeffersonianSplitResult. |
| section | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | The polygon to split. |
| sectionNumber | Int32<!– System.Int32 –> | The number which the polygon belongs to. |
| unit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | Current geography unit |
| cornerPointTolerancePercentage | Int32<!– System.Int32 –> | Percentage value of the tolerance, e.g. 50 means 50% |
| splitMode | JeffersonianSplitMode<!– ThinkGeo.MapSuite.Core.JeffersonianSplitMode –> | |
| isSection | Boolean<!– System.Boolean –> |
| Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Feature} –> |
