This class uses the grid file provided.
InMemoryGridFeatureLayer]]**
* **Parameters**:[[ThinkGeo.MapSuite.Core.GridCell[,]|GridCell[,]
* DeclaringType:N/A
* Summary:N/A
</div>
=== Protected Constructors ===
=== Public Methods ===
=== Protected Methods ===
=== Public Properties ===
Attribution
* Return:String
* Summary:N/A
BlueTranslation
* Return:Single
* Summary:N/A
CellSize
* Return:Double
* Summary:Gets the cell size from the grid.
ColumnCount
* Return:Int32
* Summary:Gets the column number from the grid.
DataValueColumnName
* Return:String
* Summary:N/A
DrawingExceptionMode
* Return:DrawingExceptionMode
* Summary:N/A
DrawingMarginInPixel
* Return:Single
* Summary:N/A
DrawingMarginPercentage
* Return:Double
* Summary:N/A
DrawingQuality
* Return:DrawingQuality
* Summary:N/A
DrawingTime
* Return:TimeSpan
* Summary:N/A
EditTools
* Return:EditTools
* Summary:N/A
FeatureIdsToExclude
* Return:Collection<String>
* Summary:N/A
FeatureSource
* Return:FeatureSource
* Summary:N/A
GeometryValidationMode
* Return:GeometryValidationMode
* Summary:N/A
GreenTranslation
* Return:Single
* Summary:N/A
GridMatrix
* Return:GridCell[,]
* Summary:N/A
HasBoundingBox
* Return:Boolean
* Summary:This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GridFeatureLayer, we override this API and mark it as true.
IsGrayscale
* Return:Boolean
* Summary:N/A
IsNegative
* Return:Boolean
* Summary:N/A
IsOpen
* Return:Boolean
* Summary:N/A
IsVisible
* Return:Boolean
* Summary:N/A
KeyColors
* Return:Collection<GeoColor>
* Summary:N/A
MaxRecordsToDraw
* Return:Int32
* Summary:N/A
* Return:String
* Summary:N/A
NoDataValue
* Return:Double
* Summary:Gets the NoDataValue from the grid.
QueryTools
* Return:QueryTools
* Summary:N/A
RedTranslation
* Return:Single
* Summary:N/A
RequestDrawingInterval
* Return:TimeSpan
* Summary:N/A
RowCount
* Return:Int32
* Summary:Gets the row number from the grid.
Transparency
* Return:Single
* Summary:N/A
WrappingExtent
* Return:RectangleShape
* Summary:N/A
WrappingMode
* Return:WrappingMode
* Summary:N/A
ZoomLevelSet
* Return:ZoomLevelSet
* Summary:N/A
=== Protected Properties ===
0BU=
* Return:TimeSpan
* Summary:N/A
0xU=
* Return:TimeSpan
* Summary:N/A
IsOpenCore
* Return:Boolean
* Summary:N/A
yhU=
* Return:Int64
* Summary:N/A
zRU=
* Return:Int64
* Summary:N/A
=== Public Events ===
DrawingAttribution
* Event Arguments:DrawingAttributionLayerEventArgs
* Summary:N/A
DrawingException
* Event Arguments:DrawingExceptionLayerEventArgs
* Summary:N/A
DrawingFeatures
* Event Arguments:DrawingFeaturesEventArgs
* Summary:N/A
DrawingProgressChanged
* Event Arguments:DrawingProgressChangedEventArgs
* Summary:N/A
DrawingWrappingFeatures
* Event Arguments:DrawingWrappingFeaturesFeatureLayerEventArgs
* Summary:N/A
DrawnAttribution
* Event Arguments:DrawnAttributionLayerEventArgs
* Summary:N/A
DrawnException
* Event Arguments:DrawnExceptionLayerEventArgs
* Summary:N/A
RequestedDrawing
* Event Arguments:RequestedDrawingLayerEventArgs
* Summary:N/A
RequestingDrawing
* Event Arguments:RequestingDrawingLayerEventArgs
* Summary:N/A
===== Public Constructors =====
=== InMemoryGridFeatureLayer() ===
This is the default constructor for the class.
==== Remarks ====
==== Parameters ====
Go Back
=== InMemoryGridFeatureLayer(GridCell[,]) ===
==== Remarks ====
gridMatrix
* Type:GridCell[,]
* Description:N/A
canvas
labelsInAllLayers
obj
gridDefinition
gridInterpolationModel
outputStream
gridDefinition
extentToRefresh
bufferTime
bufferTimeType
extentsToRefresh
bufferTime
extentsToRefresh
bufferTime
bufferTimeType
bufferTime
bufferTimeType
bufferTime
extentsToRefresh
extentToRefresh
extentToRefresh
bufferTime
returningColumnNames
canvas
featuresForFilters
labelsInAllLayers
currentZoomLevel
marginWorldExtent
canvas
attribution
canvas
labelsInAllLayers
canvas
e
canvas
e
This method returns the bounding box of the FeatureLayer.
This method is called from the concrete public method GetBoundingBox. It returns the bounding box of the FeatureLayer.
args
e
e
e
e
args
e
eventArgs
eventArgs
Return Type:String
Return Type:Single
Return Type:Double
Return Type:Int32
Return Type:String
Return Type:DrawingExceptionMode
Return Type:Single
Return Type:Double
Return Type:DrawingQuality
Return Type:TimeSpan
Return Type:EditTools
Return Type:Collection<String>
Return Type:FeatureSource
Return Type:GeometryValidationMode
Return Type:Single
Return Type:GridCell[,]
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Collection<GeoColor>
Return Type:Int32
Return Type:String
Return Type:Double
Return Type:QueryTools
Return Type:Single
Return Type:Int32
Return Type:Single
Return Type:RectangleShape
Return Type:WrappingMode
Return Type:ZoomLevelSet
Return Type:Boolean
Return Type:Int64
Return Type:Int64
