This layer is backed by memory and is typically used for temporary features.
If you use this constructor, then you need to specify the FeatureSource column manually.
featureSourceColumns
This method build a spatial index for a passed group of featurs which increases access speed.
This method will clear all the features included in the feature source.
canvas
labelsInAllLayers
This method returns the columns of data for the InternalFeatures in this Layer.
You should set the column names for the data that the InternalFeatures will hold. For example, if you have some features that represent road signs, then one column you may want to add is “Sign Type”. Then, for every Feature you add to the layer, you need to add the “Sign Type” and a value to the InternalFeatures' ColumnValues dictionary. If you provide this information, then you can use things like ValueStyles, Labeling, etc. based on the columns you have defined.
extentsToRefresh
bufferTime
bufferTimeType
bufferTime
bufferTimeType
extentToRefresh
bufferTime
bufferTimeType
extentsToRefresh
bufferTime
canvas
featuresForFilters
labelsInAllLayers
currentZoomLevel
marginWorldExtent
canvas
labelsInAllLayers
Return Type:String
Return Type:Single
This property gets the columns of data for the InternalFeatures in this Layer.
Return Type:Collection<FeatureSourceColumn>
Return Type:DrawingExceptionMode
Return Type:Single
Return Type:Double
Return Type:DrawingQuality
Return Type:TimeSpan
Return Type:Collection<String>
Return Type:FeatureSource
Return Type:GeometryValidationMode
Return Type:Single
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In InMemoryFeatureLayer, we override this API and mark it as true.
Return Type:Boolean
This property gets the dictionary that holds your InternalFeatures.
The dictionary is a quick way to access your InternalFeatures. You can easily add, remove or edit features in this dictionary and they instantly take effect in the layer. You can always use the EditTools to do the same thing, but this is a shortcut, as the data is backed in memory so it is very pliable.
Return Type:ThinkGeo.MapSuite.Core.GeoCollection<T>[[ThinkGeo.MapSuite.Core.Feature, MapSuiteCore, Version=9.0.0.0, Culture=neutral, PublicKeyToken=null|GeoCollection<T>]]
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Int32
Return Type:String
Return Type:QueryTools
Return Type:Single
Return Type:Single
Return Type:RectangleShape
Return Type:WrappingMode
Return Type:ZoomLevelSet
Return Type:Boolean
Return Type:Int64
Return Type:Int64
