<!– Class –> This layer is backed by memory and is typically used for temporary features.
This layer is backed by memory and is typically used for temporary features. You can use the MapShapes layer for user-drawn InternalFeatures, InternalFeatures that come from an external device such as a GPS unit, or any InternalFeatures that are not saved to disk or a database.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.FeatureLayer ThinkGeo.MapSuite.Core.InMemoryFeatureLayer
InMemoryFeatureLayer | This is a constructor for the class. | ||
InMemoryFeatureLayer | IEnumerable<FeatureSourceColumn>, IEnumerable<Feature> | This is a constructor for the class. | |
InMemoryFeatureLayer | IEnumerable<FeatureSourceColumn>, IEnumerable<BaseShape> | This is a constructor for the class. |
BuildIndex | This method build a spatial index for a passed group of featurs which increases access speed. | ||
Clear | This method will clear all the features included in the feature source. | ||
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetColumns | This method returns the columns of data for the InternalFeatures in this Layer. | ||
![]() LoadLayer | Uri | Layer | |
![]() LoadLayer | Stream | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape | Layer | |
CloseCore | Layer(overriden) | ||
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer(overriden) | ||
MemberwiseClone | Object | ||
OnDrawingFeatures | DrawingFeaturesEventArgs | FeatureLayer | This method raises the DrawingFeatures event. |
OnDrawingWrappingFeatures | DrawingWrappingFeaturesFeatureLayerEventArgs | FeatureLayer | |
OpenCore | Layer(overriden) | This method opens the Layer so that it is initialized and ready to use. | |
SetupTools | FeatureLayer | This method sets up the EditTools and QueryTools objects. | |
SetupToolsCore | FeatureLayer | This method sets up the EditTools and QueryTools objects. |
DrawingMarginInPixel | Single | FeatureLayer | |
DrawingQuality | DrawingQuality | FeatureLayer | This property gets and sets the general drawing quality for the FeatureLayer's canvas. |
EditTools | EditTools | FeatureLayer | This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer. |
FeatureIdsToExclude | Collection<String> | FeatureLayer | A collection of strings representing record id of features not to get in the Layer. |
FeatureSource | FeatureSource | FeatureLayer | This property gets the FeatureSource for the FeatureLayer. |
GeometryValidationMode | GeometryValidationMode | FeatureLayer | |
HasBoundingBox | Boolean | Layer(overriden) | This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In InMemoryFeatureLayer, we override this API and mark it as true. |
InternalFeatures | GeoCollection<Feature> | This property gets the dictionary that holds your InternalFeatures. | |
MaxRecordsToDraw | Int32 | FeatureLayer | |
QueryTools | QueryTools | FeatureLayer | This property gets the QueryTools that allow you to easily query Features from the Feature Layer. |
WrappingExtent | RectangleShape | FeatureLayer | |
WrappingMode | WrappingMode | FeatureLayer | Thie property gets or sets whether allow wrap date line. |
ZoomLevelSet | ZoomLevelSet | FeatureLayer | This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer. |
IsOpenCore | Boolean | Layer(overriden) |
DrawingFeatures | DrawingFeaturesEventArgs | FeatureLayer | This event is raised when features are about to be drawn in the layer. |
This is the default constructor. If you use this constructor, then you need to specify the FeatureSource column manually.
This constructor allows you to provide the FeatureSource columns and features for the layer.
| featureSourceColumns | IEnumerable<FeatureSourceColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.FeatureSourceColumn} –> | This parameter is the FeatureSourceColumn in this class that you want to use. |
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | This parameter represents the features in this class that you want to use. |
This constructor allows you to provide the FeatureSource columns and shapes for the layer.
| featureSourceColumns | IEnumerable<FeatureSourceColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.FeatureSourceColumn} –> | This parameter is the in this class that you want to use. |
| shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.BaseShape} –> | This parameter represents the shapes in this class that you want to use. |
<!– ThinkGeo.MapSuite.Core.InMemoryFeatureLayer –> Go Back
You should set the column names for the data that the InternalFeatures will hold. For example, if you have some features that represent road signs, then one column you may want to add is “Sign Type”. Then, for every Feature you add to the layer, you need to add the “Sign Type” and a value to the InternalFeatures' ColumnValues dictionary. If you provide this information, then you can use things like ValueStyles, Labeling, etc. based on the columns you have defined.
| Collection<FeatureSourceColumn><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.FeatureSourceColumn} –> |
<!– static –>
<!– static –>
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
| e | DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.Core.DrawingFeaturesEventArgs –> | This parameter represents the event arguments for the event. |
<!– ThinkGeo.MapSuite.Core.FeatureLayer –> Go Back
| e | DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingWrappingFeaturesFeatureLayerEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
The DrawingQuality enumeration allows you to control, in a macro sense, the drawing quality that will be used in the GeoCanvas. Each GeoCanvas, which is responsible for drawing of the features, may have its own specialized drawing quality properties. What the DrawingQuality enumeration does is define some general guidelines for each GeoCanvas. For example, if you set the DrawingQuality to HighSpeed, then inside of the GdiPlusGeoCanvas there is a profile for HighSpeed. This profile sets specific properties, such as the smoothing mode and composing drawing mode of the GdiPlusGeoCanvas. As each GeoCanvas may have different drawing quality properties, this offers a general way to control drawing quality and speed.
If you need complete control over how a specific GeoCanvas will draw, then you can set the DrawingQuality to Custom. This will tell the specific GeoCanvas to use the properties on its own object instead of one of the pre-defined profiles. If one of the profiles – such as HighSpeed or HighQuality – is set, then the specific GeoCanvas ignores its own properties for drawing quality.
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
| EditTools<!– ThinkGeo.MapSuite.Core.EditTools –> |
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
| FeatureSource<!– ThinkGeo.MapSuite.Core.FeatureSource –> |
| GeometryValidationMode<!– ThinkGeo.MapSuite.Core.GeometryValidationMode –> |
The dictionary is a quick way to access your InternalFeatures. You can easily add, remove or edit features in this dictionary and they instantly take effect in the layer. You can always use the EditTools to do the same thing, but this is a shortcut, as the data is backed in memory so it is very pliable.
| GeoCollection<Feature><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Feature} –> |
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
| QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –> |
| WrappingMode<!– ThinkGeo.MapSuite.Core.WrappingMode –> |
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
| ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
| Event Arguments |
| Event Arguments |
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
