This class uses the grid file provided.
GenerateGridMatrix(GridDefinition,GridInterpolationModel)
This method is called from the concrete public method GetBoundingBox. It returns the bounding box of the FeatureLayer.
1xU=(GeoCanvas,Dictionary<String,Collection<Feature»,Collection<SimpleCandidate>,ZoomLevel,RectangleShape)
This should be the complete path and filename of a grid file.
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GridFeatureLayer, we override this API and mark it as true.
